Question about DeLonghi DCM485 Coffee Maker
Won't brew The bars came on and before I could decalcify the machine stopped working. It is exactly one year and two weeks old. I have tried resetting. Now it shows a clear symbol instead of lines going through it, but it still does not work even though there is power to it and I can stop, start, etc. Nothing happens. Please help. Thank You
  • 2 more comments
  • netsanchez Jan 03, 2008
    I dont make de descalcification after 1 and a half year, and today it doesnt work, the machine is prower on but doesnt work, what can I do? I shoul made the desacification before, that`s the main problem?
  • miloluk Jan 07, 2008
    will not brew has power wii switch but no heat, checked thermal is ok, possible heating element . needs parts where to order.
    paul s.
    will not brew,need heating element where to order parts?
  • Cindilou Jan 11, 2008
    Hi, ours is also more or less one year old plus one month and same issue; however, we HAVE decalcified in the past and it is time again, but now it suddenly won't brew the coffee. Any ideas? Help Please! Cindi
Yosemitesam, tomorrow I will ask this for an expert here in Mexico, when I knew the problem i will let you Know..
Posted on Jan 03, 2008
Not brewing
it sounds like the pump inside is bad, from either a clog or fuse perhaps.the pump sends the water thru so thats the likley problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Jun 02, 2009 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi Water Problem/ my machine is leaking water and sort of coffee grounds. I have decalcified it several times, but it continues to leak. It is an office machine is 3 years old and I don no
Easiest way is to open the machine and find the blockage then clear it out and then get on a regular descale cycle. Check the brew unit also to make sure that it is not blocked. You model only has one boiler so if you're getting hot water from the steam wand it is possible that the problem is in the brew unit.
Its not making the coffee its just makes a little then stops
You both may have deeper issues, but it is definitely not too new to be decalcified. It is very much worth a shot. I have a Cusinart coffeemaker and a Cuisinart espresso maker, and both of them needed to be decalcified in the first month (of course, I live in an area with hard water).
-Tha Mp3 Doctor
Jan 25, 2009 | Cuisinart DCC-1200 Coffee Maker
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Steam from brew head, but no water
  1. If you take the coffee filter and head it in light, can you see a little hole in the middle? if not, try to clean it else you have to replace it.
  2. Can you brew out water without the filter holder in the machine? If not, loosen the screw in the middle on the machine where the filterholder shall be and take of the filter. Clean the filter and put it on the machine again.
Hope this help you
Jun 10, 2008 | Breville ESP8XL Espresso Machine
Cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
May 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off during brew cycle
I to have been battling this same problem on and off for a couple of years, and have been trying to find out why it thinks it id done brewing. I have had some success but exactly what fixes it I don't know.
I called Cuisinart and they told me to change the water filter in it. This didn't work, but I did see some grounds and even a bean had gotten under the filter. I cleaned that out and it fixed it, that time. If you don't have a filter, shine a light down the water reservoir and make sure you don't see anything.
Other than that I do a bunch of cleaning cycles with, Brew Rite Cleaner, Whink Automatic Drip Coffeemaker Cleaner, and vinegar. Don't mix them, just follow the directions on each. Follow with a bunch of rinse cycles. I still don't know which one does the most to fix the problem. For all I know it could just be all of the rinse cycles.
Just keep trying, there is hope that you won't have to tend to your coffee maker forever.
Nov 29, 2007 | Cuisinart DCC-1200 Coffee Maker
Won't brew
bring white vinegar to a boil and pour it into the perforated top, the water reservoir and the link between the water reservoir and the brew basket. let sit a few minutes, pour it out and do it again.
put the water reservoir back in, put water and vinegar solution ( half and half) in. Try to start it again. Mine did this last year and this fixed it right away. Try to clean the coffee maker using the vinegar solution once a month to avoid this problem.
DeLonghi DCM485 Coffee Maker Logo
295 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
