Home | Whirlpool | LER4634J Electric Dryer | Dryer does not heat eno...
Whirlpool LER4634J Electric Dryer
Problem for Whirlpool LER4634J Electric Dryer
Dryer does not heat enough. I have plenty of air
By pfshep on Oct 31, 2009
Dryer does not heat enough. I have plenty of air flow. Usually have to run clothes through 2 to 3 times
Best Solution
posted on Oct 31, 2009
Very Helpful)
localwonder
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 92%, 2780 votes
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE(If the Thermostats and fuse check out ok, replace the element. Element failure is uncommon but, it may fail in certain cases))
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool LER4634J Electric
Questions and Unsolved Problems for Whirlpool LER4634J Electric
Do you recommend Whirlpool LER4634J Electric Dryer?
Answer
Answer
coil looks good but not drying
Answer
my dryer is working good but there is no heat
Answer
Runs a minute or two heats up then stops model LEC 8858EQO
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool LER4634J Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14767
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
