Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi wd-73733 73 need missing screws
The stand that came with this above referenced product was defective/screws are missing. Shop NBC instructed me to directly contact you for assistance.
My Email is:
Shop NBC PO 54411684
  • 1,153 Answers
Is this a tv problem or stand problem, if stand then I guess you will need to locate another for this set. I guess you could try or Mitsubishi direct
Posted on Jan 02, 2008
I installed new lamp comes on then goes off and I hear a buzzing sound. Could it be that it's not installed properly for get light to come on. I had to use different screws because the new lamp didn't
How do you know the solution is "simple"? No always is simple. Bussing is high voltage missing. Like is bad conection to the lamp. Check conections of it.There is some bad about the conections of lamp. I guess.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
I see no picture
Televisions covered: Mitsubishi DLP High-Definition Televisions:
C Series: WD-60C8, WD-65C8, WD-73C8
735 Series: WD-60735, WD-65735, WD-73735
736 Series: WD-65736, WD-73736
835 Series: WD-65835, WD-73835
Here's an online version of your televison's (94 page) "Owner's Guide":
It sounds like the lamp in your "Mitsubishi Lamp-Cartridge" blew.
If your TV remains under warranty, you'll want to call Mitsubishi at 1-800-553-7278, and you'll need to have (a) Mitsubishi Model number, (b) serial number, (c) TV purchase date, and you'll have to ship the old lamp module back to Mitsubishi so that:
"All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect verification."
Return old Lamp-Cartridge to:
Mitsubishi Digital Electronics America
1001 Cherry Drive, Suite 2
Braselton, Georgia 30517
If you have trouble finding your TV's information, you need better "Warranty Management". Warranty Management can be done with software, or on paper. You may even choose to toss all your Owner's Manuals into a box, with the receipts. In case anything malfunctions/needs to be reprogrammed/reset then the manual & spare parts/cables (in a large Zip-Loc(R) baggie or two) can be quickly located and consulted.
If you television happens to be out of warranty, a nice (expensive) new lamp module can be ordered from Mitsubishi by calling 1-800-553-7278, or by ordering online at
Refer to pages 75-76 of your Owner's Guide for complete Lamp-Cartridge module replacement instructions (with nice illustrations).
Your TV's Lamp-Cartridge part number is: Mitsubishi 915B403001
Here's an online source for the Mitsubishi 915B403001 Lamp-Cartridge:
Note that with the offerings, you can purchase the lamp only for $109, or the entire lamp-cartridge module for $129. So you can save yourself $20 if you're handy. Remember to keep all fingerprints off the lamp glass element - this small amount of oil will weaken the glass, and cause premature failure of the lamp. In the event that you get a fingerprint on the lamp glass, erase it thoroughly with rubbing alcohol. Alternatively, one may prevent fingerprints with latex gloves (make sure you haven't an allergy to latex, though).
If the reason that the lamp blew turns out to have been a clogged Lamp-Cartridge Filter (once you have the Lamp-Cartridge out of the TV and in your hand, you'll be able to easily see the mesh filter), then place a regular PM (Preventative Maintenance) of this filter on your calendar.
Dec 17, 2011 | Mitsubishi WD-60735 Projection Television
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
Have a WD-52725 Mitsubishi TV. Notices lines
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
May 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Screen Removal - Mitsubishi WD-62527
Pull the SPEAKER-GRILLE away from the cabinet to remove.
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
Aug 01, 2009 | Mitsubishi WD-65735 Television
Mitsubishi WD 73727 73in
Contact Mitsubishi with the proof of this and demand a new TV set. Maybe it is the service shop causing this, your warranty should also be extended for the time you were out of the use of the TV set while waiting for parts. If this does not work, the state attorneys office should be able to get you a new set or at least this one repaired. Good Luck
Sep 26, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
