Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Need code to a motorola comcast box
By melissamoy1 on Oct 31, 2009
need code to a motorola comcast box
Solution #1
posted on Nov 01, 2009
Not Rated)
Anoint2020
Rank: Guru
Rating: 86%, 113 votes
If you have a Brookstone remote this will work for you.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control, keep in mind when not trying to use this sequence with any other remote than a Brookstone you might have to have the unit on when doing this, then it will turn off when you have the right code. I would try the first option first.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my... (More)
Answer
wont program my tv white westinghouse
Answer
i have the duff 6 in 1 remote but ive lost the user guide does anyone know how to scan to locate the... (More)
Answer
I cannot get my rca tv code for cox remote control Rca tv l40fhd41 RCA remote rc2463001/01
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote Controls Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
