Samsung 1080p LCD TV stuck on zoom
My screen seems to fall back to zoom but won;t let me take off the zoom. Why
Tom
  • 5 more comments
  • russto Jan 29, 2009
    I have the same problem. Except in the menu both zoom options are grayed out. But I am stunk in zoom when watching HD channels.
  • Anonymous Feb 24, 2009
    my tv is stuck on zoom......
  • aberman Mar 10, 2009
    My Samsung LCD is stuck on zoom in HD channels
  • Anonymous May 12, 2009
    i have the same problem with a samsung tx-r3079
  • Anonymous May 17, 2009
    I got the same problem on Samsung LCD LE46A956. Just updated the driver but no help. Does anyone know what to do ? Maybe buy a new SAT receiver ?? Pls help....thx
  • Jeannie Tirschman
    Jeannie Tirschman Jan 19, 2014
    Russto, get your cable remote and look for HD zoom button...get it back to NORMAL. I just did mine!
  • Jeannie Tirschman
    Russto, get your cable remote...look for the HD ZOOM button, click on that till it goes to NORMAL. I just fixed mine that way!
I had the same problem. It's the default setting on your HD cable box. You have to go under the cable box's "settings" and switch it from "Zoom 1" to "Normal." I found the solution on Samsung's webpage. Can't tell you how much that was driving me nuts.
Posted on Feb 15, 2010
  • lolakaminski Sep 26, 2010
    this actually worked.thank you i was trying for days to take the zoom off!!!!!
  • Heliker44 Dec 07, 2010
    THANK YOU SOOOOO MUCH !!
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
Adjust my 40 Samsung 1080p 120Hz LCD to see the entire picture. t is currently cutting off the edges; left, right, top and bottom
First check if your zoom is on..if it is switch back to normal setting. If picture is still cropped with no zoom then try go to the menu seen string and check for aspec ratio..try different sttings..
Feb 23, 2015 | Samsung UN40EH6000 40-Inch 1080p 120 Hz...
Light Blue Verticle lines in samsung UA46D7000LNXZN
flat cable on LCD display are bad,buy a new TV,it is a cheaper variant
Jan 17, 2014 | Samsung "Un46 D7000 46"" 3 D Led Lcd Tv...
Insignia TV won't pick up 1080p from Blu Ray
hi there, you did not mention what you are actually watching on the bluray player, i.e is it 720p or 1080p ?. Also, how do you know it is actually 1080p from your cable box ?. And what is the model number of your TV ?.
Oct 12, 2017 | Insignia 42" LCD Flat-Panel HDTV
The zoom won't come out when I try to turn my camera on, it just turns a little bit, then turns back to the original place, and the screen says zoom error. I've tried different batteries, and taking out...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 14, 2010 | Cameras
My tom tom one screen is broken. What can I do?
I have a tom tom xl 350, bought an extended warranty, and I have had problems with it falls off my wind shield. Well, this last time, when it fell, the screen broke. I have owned it for just under 3 months. I took it back to walmart and they said to call tom tom, which I did, tom tom told me that it doesn't cover normal ware and tare. I told them it was due to the poorly designed suction that holds it to the windshield but they wouldn't do **** and it was the same reponse from walmart. I live in the tampa Fl area andI e-mailed the local tv station and they help people with these sort of problems. They called me and told me to get as many people to e-mail them with tyhis problem and they would pursue it on our behalf. I told them if I get enough people I want to pursue a class action laws suit, which they thought was a good idea. If you type in 8 on your side in the goolge part it will bring up the station and how to e-mail them. Also, please e-mail me at Shawn@bayarearespiratory.com and I'll and your name to the list for a possible class action law suit.
Thanks
Shawn
Jun 30, 2010 | Tomtom One XL GPS Receiver
My Tom Tom 920 will not stay on the map screen for more than a few seconds.
Its sounds like a problem with the screen then. If it is still under warranty, return it
Feb 13, 2010 | Tomtom GO 920 GPS Receiver
Televison & Video Logo
6,479 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
