Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
Heater core replacement 1996 Ford Ranger
By renee_whitne on Oct 31, 2009
Do you have to remove the entire dash, including the steering wheel and speedometer panel, to replace the heater core in a 1996 Ford Ranger? The Haynes Manual states to remove 4 bolts on the plenum. Where are they, they seem to be in a good hiding place?
Solution #1
posted on Nov 01, 2009
Not Rated)
KingDWS
Rank: Guru
Rating: 90%, 172 votes
The heater core is on the passenger side of the dash.
You get everything in and out from under the dash.
Other than removing the cover you shouldn't have to remove anything else.
You should just have to remove 2-4 bolts that hold the plenum cover on, then undo the heater hose in the engine compartment, and I think two bolts along the bottom of the core and *** all drops loose.
The hard part is getting everything lined up when you put the new one back in.
Was this helpful?
Yes
No
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
it does not unlock and when i press for pass word it does not respond.The top part of screen works.
Answer
my iphone is disaled and say connect to itunes
Answer
The battery ran out so i plugged it in the plug socket charger and soon realised it wasn't doing... (More)
Answer
my i phone in i tunes mode with only emergency calls, what shoul i do..?
Answer
I have had my second Iphone in two months, it has completely turned black and will not reboot with... (More)
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in Van Nuys, CA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
