Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Five Blinking Lights
I turn it on and just hear a beeping that fades away. No audio. No video. The front LED blinks five times. It's been unplugged for almost two months and worked perfectly before I plugged it in today and fired it up. I took the back panel off and nothing appears to have burned out, but I didn't poke around or touch anything for fear of making the problem worse.
  • 5 more comments
  • stevenapryor Jan 08, 2008
    Yup, that's the model. How would something like that break all of the sudden?
    steven [dot] pryor [at] gmail [dot] com
    I appreciate the help.
    Okay, I've got the service manual. However, I won't be able to look at it until later tonight. I really appreciate the help.
    Okay, I've got the manual on my Macbook. Opened up no problem. I assume you'll need me to take the back panel off the TV.
  • stevenapryor Jan 09, 2008
    Nope. It worked perfectly up until the time I unplugged it. The only thing out of the ordinary was that it hadn't been used for two months.
    I'll take a look at the solder joints and capacitors. Not sure how long this'll take...you cool with this taking a day or two?
    Good deal... I didn't see anything suspect last night, but I want to give it another once over tonight. I'm going to use a brighter light and hopefully a better magnifying glass this time.
  • cribbit Jan 30, 2008
    I have exactly the samwe problem. Is it repairable?
  • Panasonic Master
  • 8,617 Answers
5 blinks means faulty IC4001. I dont believe that is servicable with out changing the entire module. I will check and get back to you on it. PT-47WX53 is your correct model info right?
Posted on Jan 08, 2008
  • 3 more comments
  • Sonny Berry
    Sonny Berry Jan 08, 2008
    Okay I just pulled up the service info on your Chassis its actually IC4511 which is the main signal processor. Post your email link and I will send you a copy of the service manual and then I can walk you through testing that IC as it may be a componnent down stream of the IC which is faulty.
  • Sonny Berry
    Ok I just sent out your service manual, Usually those ICs are not serviceable,but sometime a component fails feeding voltage into the IC which triggers the same fault code. Let me know when you have your service manual, and we will pros=ceed from there.
  • Sonny Berry
    Sounds Good just let me know and i will try to help you diagnose it. Glad I could be of assistance.
  • Sonny Berry
    Sonny Berry Jan 09, 2008
    yes take the back panel off and give it a look for cracked solder joints ,use a magnifying glass. Also check for any swelled capacitors. Now has the set exhibited anything even slightly before this?
  • Sonny Berry
    Yes by all means, When ever you need something just let me know and I will help you diagnose this.
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
My genie garage dooropener is blinking red on the opener motor. It is suppose to be blue.
1. If both round and long LED's are blinking, unplug the opener motor for five seconds, and replug. If the lights go back to normal, it was just a program error. If they both continue to blink, it's probably not user-serviceable.
2. If the round LED is blinking and the long LED is off, it is usually the door sensors that are obstructed or knocked out of line.
3. If the Long LED is blinking and the round LED is off, it is usually a bad roller or hinge that won't let the door move freely, something stuck in a track or a bent track.
Jul 09, 2017 | Building Materials
Five red blinks. Won't turn on.
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 30, 2014 | Televison & Video
My compaq 615 does not boot, it just turns caps' light on five times and then nothing happens
What you are seeing is a "blink code". Similar to something like a digital SOS message, your laptop is built to flash certain LED lights a specific number times to indicate a hardware problem.
According to Compaq's table of blink codes, the Caps Lock LED light blinking five times consecutively means you have a system board failure. If your laptop is still under warranty, I would contact the company immediately and have it shipped out to be serviced. Otherwise, you will need to either pay Compaq or another third-party repair shop to fix or, more likely, replace the system board.
Mar 01, 2011 | Compaq Computers & Internet
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Hi, Approximately eighteen months ago, I purchased a 42 inch plasma Panasonic television model number: TH-42pz77u) but Saturday night, the television turn off and have five blinking red lights. Then we...
The 5 blinks on the LED means that the main logic D board is defective and will need to be replace to fix the TV.
Check this site to find replacement parts to fix your plasma if you intend to DIY.
Let me know if you need further assistance.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Left tv unplugged for a few months no tv won't turn on
The first thing to do is try to turn on the set with the remote and then when it doesn't respond go to the set and hold down the MENU and INPUT buttons at the same time until the power LED starts blinking a two sequence code. Like 2 - 4 or 1 - 2. The code will keep blinking for five or six times and stop. The blinking is the microprocessor telling you why the set is not working. We techs call that a self diagnostic function. Which this set has. Just repost your findings.
May 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
