posted by JackH on Jan 02, 2008
trying to find the subject manual for the sony vaio pcv-w510g desktop.
Comment by JackH, posted on Jan 02, 2008
Thanks, shaky120, but the Vaio 510 is an all in one and isn't anything like other laptops and desktops that I've worked on in the past. I did like that video where they used a pick, though; for sure that's one way of getting into a case!!
Comment by JackH, posted on Jan 30, 2008
Thanks for that tip, mathgirl08. At least that gets me started. The reason I'm digging into this one is it was hit by lightning and I'm curious as to how much it's really damaged.
JackH
JackH
Best Solution
Hi, every desktop pc is almost the same to open up and take apart nowadays, if you want to checkout some of these videos should give you more than enough info..
http://www.youtube.com/results?search_query=disassemble+pc
All the best
John
All the best
John
Rating Locked! (?) JackH has rated this solution as Thanks for Trying
Solution #2
I bought the same computer used, and I had issues trying to find out how to open it. On the actual computer part (not the monitor) there is a button on the upper left on the side facing you. Push in that button and slide that top casing to the right while pulling up. The RAM slots are on the upper left. I haven't found an easy way to get to the hard drive, but if you find one . . . please share. Every site I found says "don't try to change the hard drive".
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Sony VAIO PCV-W510G PC Desktop
Email this problem
Email this problem
Can you Help with these PC Desktops problems?
answer Sony VAIO PCV-W510G PC...
brother thanks for ur reply..... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
