Question about Mitsubishi VS-45603 45" Rear Projection Television
Mitsubishi vs45607 dead
When I press power only a click,and nothing more thank. The TV was working fine. I did not power it on for about 5 days. Upon attempting to power it on it would not power on. The green indicator light will light for about 3 seconds and then power off. I have unplugged the power cord in hopes of resetting the TV. This did not help. What could be the issue? Furthermore, if the issue is repairable, is it worth it at this time to repair a 9 year old TV.
  • fischfly2 Aug 25, 2008
    Same problem. When i push the on switch, the green light illuminates for a few seconds and then goes out. The TV never comes on. TV is 9 years old.
  • Anonymous Apr 07, 2009
    I have the exact same problem wonder if it's worth fixing?
    Genius:
  • 1,153 Answers
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Posted on Jan 03, 2008
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
Mitsubishi 65 rear works fine yellow light starts blinking tv shuts off, when light stops can hit power and it could work fot 10 min or the next 4/5 days
All you need to know is that your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, Take care.....
Oct 01, 2010 | Mitsubishi Televison & Video
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
un plug the set and use a flashlight and look for evidence of the CRts leaking on the chassis this is a common fault with that model. It will cause a dead set.
Apr 23, 2008 | Televison & Video
Philips HDTV does not turn on
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Mitsubishi Power Problem -turns itself off.
Sounds like CRT coolant leak onto signal board = check
for work....................................................T.
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
This denotes a problem in the HV power supply and the shutdown circuit shutting down the Tv to prevent damage from a component that is drawing too much current. I would suggest that you have a repair person look at your TV and give you an estimate.
Sep 20, 2007 | Mitsubishi VS-45607 45" Rear Projection...
CS- 40503 No Power
There is no external reset, and if the set is completely dead (not even a click when the power button is pressed) then there is probably an open main fuse or defective stand-by power supply. If the main fuse is blown then there is usually a heavy short in the main power supply, and either way the set should be looked at by someone with experience in Mitsubishi sets.
Jul 04, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
