Question about RCA DRC8335
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
We bought a new RCA DRC8335 DVD/VHS Recorder/Player for Christmas. It is hooked up to our Sattelite and the reception is fine. No problems with anything except for the DVD burning.
I burned a disk just playing around to see how it went. I can see there are files on the DVD, so it did record, however the finalize screen that was supposed to appear never did when I stopped recording. When I try to view the DVD I see nothing. I can see that the counter is moving through the files, but there is nothing on the screen.
Tried the disk on the player and on my computer. No luck on either.
Can someone please give me some pointers, step-by-step, so that I can use my player.
It will play pre-recorded DVD's fine and also plays the VHS tapes. Just won't play back what I have recorded.
Thanks so much,
  • JRRieck1737 Jan 19, 2008
    I have the same kind of problem. I set my DVD recorder up on the timer to record a movie on it at night after I've gone to bed and it goes through the motions and then the next day, I turn it on and get to the main menu and it doesn't have the play disc highlighted and then when I go to play disc, it tells me it's a blank tape. I have recorded on it while the tv is on and and I also record on the VCR without any problems, but when I do it with the tv off is when I have the problem. I have a satellite box but as far as I can see it it hooked up correctly. I also had to purchase the RF Modulator because my TV is a little older than these newer one. I have called RCA help line 2-3 times and all I get is people who can't seem to help me.
    Problem Solver:
  • 7 Answers
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Posted on Jan 06, 2008
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
Rca dvd/vhs recorder model #DRC8335
By the process of elimination I determined that the 1998 TV I was working with was to old to accept digital signals. Thanks any way D. G.
Feb 13, 2008 | Televison & Video
Can't view a DVD Recorded on RCA DRC8335
whats the format of the dvd writer you used,? cus sometimes the computer cant really read a unknown format of dics. try to use a nero or divx to read it.
Jan 25, 2008 | RCA DRC8335
Don't understand about the word "filter"?Filter tv programs?Do you mean delete commercials or filter the bad video noise?
More details please!
Jan 09, 2008 | RCA DRC8335
Your question is not clear?Are you asking a blank dvd on a home line dvd recorder/player or a blank dvd from a computer or a blank dvd in a dvd camcorder?
Jan 06, 2008 | RCA DRC8335
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Recording a movie that I have on my pc to a disc useing a RCA DRC8335
if you have an s video out as well as audio out on your laptop connect it to svideo and corrasponding audio input on dvd recorder. hook up recorder to a TV to see the movie your transfering then press record on drc that should be good luck
Sep 01, 2007 | RCA DRC8335
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
RCA DRC8335 Logo
196 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
