Question about Motorola Mobility HT820 Wireless / Cable Headset
I can no longer charge my HT820 nor Pair with my phone all of a sudden
When I charge my HT820 it flashes blues continuously, but will not completely charge. Also, I cannot pair it to my phone anymore.... PLEASE HELP
  • Anonymous Apr 09, 2009
    Battery won't hold charge.  I call motrola and they said buy a new one.  I would like to change the battery if anyone knows how to do that.
    Leepers
Same here. A real peice of trash!
Posted on Apr 01, 2008
Pair ht820 with ipad
have you tried resetting the headset? or put it in pair mode?
Apr 27, 2013 | Motorola Mobility HT820 Wireless / Cable...
Cant listen to music on my Blackberry Pearl using HT820
I'm not familiar with Bluetooth and Blackberry's but I think you need a driver or you need to "sync" your media player on your Blackberry with your headphones.
I'll do some research and get back to you.
Feb 20, 2008 | Motorola Mobility HT820 Wireless / Cable...
Can not pair my Vibe VE 1089 bluetooth keyboard with my iPad mini.
The manual for the Vibe iPad Bluetooth Keyboard Folio is completely wrong. To turn on the keyboard, press and hold the button above the word "charge" in the upper right hand of the keyboard. Blue lights beneath the word "power" and beneath the Bluetooth symbol should flash. In order to pair the keyboard, press the same button above "charge" and hold for a shorter time. The light beneath the Bluetooth symbol should flash.
Feb 06, 2013 | Apple Ipad I-pad
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
Jun 17, 2011 | Jabra BT135 Bluetooth Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I have a motorola HT820 Bluetooth stereo headphone. And I want to pair it with my Nokia 3110c. But every time I search for the paring device it shows no result. How can I pair my headphone with my nokia...
Make sure your headphones are turned off. Hold call button for 6 seconds, until you see the light steadily lit. Now pair with your phone: Motorola HT820, and type passkey: 0000. Done!
Dec 18, 2010 | Motorola Mobility HT820 Wireless / Cable...
I have an Explorer 210 series. It will no longer pair
Just this morning I was able to pair this headset with my phone. Before, it was paired to my PS3. The key is to hold down the big round button on the outside until the light flashes red/blue (this is quick-pair mode) then just have your cellphone search for bluetooth devices and you're done!
Oct 25, 2009 | Plantronics Explorer 220 Bluetooth Headset...
After 6 weeks, phone is dead
still warrentty time so contact ur uniden cordless phone dealer
Jul 19, 2009 | Uniden Cordless Phone
Motorola Mobility HT820 Wireless / Cable Headset Logo
412 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
