Maytag front end washer mahh5500b
I spent $9.00 to get advice in which the one guy told us to sell the machine and buy a new one. How can you sell a machine that isn't working properly and we have too much wrapped up into it to let it go. Fwadley was the last one I wrote to on Dec. 24 with no response. I just replaced the mother board in which was suggested that would solve the problem. This solved the dispenser problem and partially solved the water problem. The current problem is that when you set it at wash hot and rinse cold it runs hot all the way through. They said it might be low water pressure or plugged screens in which the pressure is good in both the hot and cold water. I have checked all the different problems that people were having but not like ours I would appreciate any advice other than taking it to a repair shop in which they have already drained us of about $300.00 or more.
  • bagpiper Jan 03, 2008
    Maybe I forgot to tell you that it will run cold water when you set it at wash cold and rinse cold. What is happening is that it won't change over to cold rinse when you set it at wash hot or warm and rinse cold. If there is a valve control that is malfunctioning then that is something else to order.
  • jstirton Jul 07, 2008
    How do I check to see if the Temp sensor switch is working?
    Sergeant:
    Champion:
  • 262 Answers
OK CHECK THE COLD SIDE OF THE WATER INLET VALVE IT SOUNDS LIKE EITHER IT IS STUCK CLOSED OR NOT GETTING POWER THIS VALVE IS THE ONE THAT THE HOSES CONNECT TO THE MACHINE FIRST MAKE SURE THE COLD HAS WATER GOING THROUGH HOSE TO MACHINE I DON'T WANT TO INSULT YOU BUT YOUD BE SURPRISED HOW MANY PEOPLE OVER LOOK THIS KINDA THING PLEASE DONT TAKE IT THE WRONG WAY EMAIL ME BACK AND LET ME KNOW WHAT YOU FIND
Posted on Jan 02, 2008
  • Bill Dozier Jan 04, 2008
    oohhhh there is a temp sensor switch that senses the tenp of the water entering the machine on most models do you get any codes or flashing lights?? the sensor is in line with the water line entering to the dispenser see if you have one if so check it see if its working if it is the selector switch may be bad get back with me on what you find well get ya running
I need to fix the door of my Maytag Neptune Washing machine. It was off-balance with a bit of water in it and the door would NOT unlock so I pried it open with a screw-driver. Now it will not close
my advice is too leave it alone till the repair guy comes out
chill with the still
and let it alone
youll need to get spares i think to replace the bent metal perhaps
most often make do and mend
but better to let the repair guy do it
he is there anyway so leave him too it
foot the bill and livd and learn
dont pry things open!!!
if your locked out its for a reason
!!!!!!! stay mr patient always
Dec 07, 2014 | Maytag Washing Machines
On going problems with our model mahh5500b maytag neptune washer
Hello, I am sorry for your lost time and money. I know you would like to fix this, but at what cost and time you are willing to put in it. You can buy a new one for what you have spent in time and money. I would sale it, and get anything back out of it you can, and go get you a new one with a warrenty. Good Luck. Farren
Dec 24, 2007 | Washing Machines
The clothes are soaking wet after the run on the machine. It seems the spin function is not working. I have a maytag neptune model front load.
I have the same problem. I have spent about $1,400 in repairs on this damn machine since we bought it about 8 years ago. It works for a bit then something else goes wrong. This is the fourth time I've had this problem.
It's the belt, it's the motherboard, its this its that $200 a pop. Just enough to say ok, any more I'd buy a new one, then a few months later something else happens.
What happened to Maytag? My mom and grandmother both had maytags for years, decades without an issue. The new ones ****.
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error dc,uc and bangs during spin
Vic
I have posted many times on this forum my fix, if you have basic mech. skill sets you could try my maintenance fix. There was no real out of pocket cost I had a can of WD-40. If you can’t tackle, direct the service tech to a possible troubleshooting solution. See my post of 12/15 at this link, it has worked for a few forum members.
http://www.fixya.com/support/t350953-code_dc_appears_trouble_draining
Also have te svr tech read my comment of 1/19 in my trying to understand why the machine gives dc/UC errors in spin cycle.
Found clutch on ebay for this machine; http://cgi.ebay.com/12002211-NEW-MAYTAG-Washer-Pulley-and-Clutch-ASSY_W0QQitemZ110334944433QQcmdZViewItem
There are supplier links at this site for parts,
Good luck.
Jan 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
1998 Neptune Washer
I agree with his diagnosis. The rear bearings have gone bad and will eventually either seize or start ripping through the outter tub. It is expensive to replace. However It is worth replacing. You will spend a similar amount of money or more on a new machine. The guy you called probably doesn't want to do the job and just said buy a new one. Also whirlpools and maytags at this point are one in the same about 1 year ago maybe alittle more whirlpool bought maytag so you will see more washers that look like whirlpools with a maytag name on it
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
My washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the "ON" led just light up 3-5 sec then turn off
my washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the led just light up 3-5 sec then turn off
Aug 21, 2008 | Maytag Neptune Washer
Front Load MAH2400AWW Washer
sounds like you have a short in control board on washer buy service smart agreement from sears it will cost a little and cover up to 500.00 or give you 500.00 towards replacement value, dryer if you have heat its your vent in wall not breathing well , it will cause long dry times
Feb 13, 2008 | Maytag MAH2400A Front Load Washer
Washing machine
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and it costs $800 to replace the unit with the bearings. They will not do anything about it except try to sell you a new washer.
I will not buy this washer again (especially from Sears).
Jan 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
