Question about Midland 1001Z 40-Channels Base CB Radio
Horrible Noise I have recently developed a horrible screeching in my radio. It is not affected by the volume of the unit, and is only heard if the radio recieves another broadcast or if the squelch is turned up. The unit is only 5-6 months old. I know nothing about cb's, so I don't even know where to start troubleshooting. Any suggestions??? Thanks
    Novelist:
    Champion:
  • 211 Answers
It may be a cold solder joint on one of the stand up boards. Check all your connections and solder any bad joints.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Power steering pump engine
ROSE;
its your pump internal seals worn. letting past under load, & the screeching noise is drive belt under strain when turning, u will need a replace meant unit they are returnable and will give u a reconditioned unit, or u can by neww if u want at your local motor factor
Oct 25, 2013 | 1992 Oldsmobile Cutlass Ciera
Horrible screeching noise on the wash cycle (when it agitates). waited too long to call for repair (it WAS still washing ok) and now it won't do a thing.
Check underneath for failed belt Check if the pulleys will turn by hand. If anything is seizes up consider a new machine as the replacement part plus labour will be more than a new unit.
Aug 17, 2013 | Whirlpool Cabrio Washing Machines
Galaxy ace makes screeching noise when calling
try to reflash your phone because it mustnt hardware problem
Jan 29, 2013 | Samsung Galaxy Cell Phones
Turns over but wont crank...horrible screeching noise
To clarify, if the engine cranks or turns over but won't start, look for a stuck pulley on the engine. You may be hearing the belt slipping on that pulley. Take the belt off and try turning each pulley - also try starting the engine with the belt off.
Jun 24, 2012 | 1998 Buick LeSabre
2000 MAZDA 626 IGNITION SWITCH
I have the exact make, model, year in the repair shop right now with the same symptoms. Horrible screeching noise after starting the vehicle, and smoke coming from the ignition area. Most likely it is a short in the ignition switch. It could have also affected the starter module but I would start with the ignition switch.
Jun 22, 2012 | Mazda 626 Cars & Trucks
Starter motor cranks well but emits a horrible screeching noise as it comes to rest after starting engine.. I suspect the bushing in gearbox housing. Anyone experienced this prob. Regards Warren
actually this sound to me as to be the kick out bearing on the starter itself. after it has been on the car for a few years they tend to get moisture into the outer bearing on the starter this washes the grease out over time and it makes a horrible growling, screeching, or rubbing noise after starting. this starter should be replaced in the near future if not it will seize up and just click when trying to start the car....... I hope this has been helpful.
Jul 20, 2009 | Audi A3 Cars & Trucks
97 Neon Expresso, Schreeching Fan
Both your air con and defogger (I am assuming you mean front windshield defroster setting, and not the back window) engage the air conditioner pump/compressor.
The screeching can be either a bad belt or a bad compressor.
How long has it been since the belt was changed? If it is old, and slipping, it will cause the screech at speed.
If the belt has recently been changed, and is adjusted properly, I would start looking that the air compressor pump.
Nov 12, 2008 | 1997 Plymouth Neon
Radio issues
could not find an amp behind rear seat as suggested
speaker seemed to be blown
however a replacement speaker (new)
made same horrible noise
3 others work fine
Aug 26, 2008 | 1992 Acura Legend
Midland 1001Z 40-Channels Base CB Radio Logo
96 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
