Question about Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner
Computer freezin When I go into control panel and click on the Lite-on combo (Model SOHC 52636 K) description for properties, the whole system freezes. This also happens when I try to burn a disk or read a disk.
  • 1 more comment
  • noncrypto Jan 03, 2008
    to cptnkirk,
    I clicked on the drive and checked properties. My computer promptly frooze up.
  • noncrypto Jan 06, 2008
    I tried your solution including disconnecting the drive and booting in safe mode then back to normal. I also downloaded the lastest firmware. Nothing!!! Maybe the drive is toast? The strange part is I can load software from the drive and occasionally burn files to cd's, but then all of a sudden I will put a cd in, and my system freezes.
    I tried your solution. It didn't work. I even disconnected the drive, went into safe mode, turned off the computer. I did this a couple of times. After reconnecting, the drive installed and I had the same problems.
  • 39 Answers
Go into the control panel click the hardware icon, click "view installed hardware", click the drive, try clicking update driver and tell me what happens.
Posted on Jan 02, 2008
  • Kirk Bonner
    Kirk Bonner Jan 04, 2008
    Go to Start-> Settings -> Control Panel -> System -> Click "Hardware" tab -> Click device manager button -> Double click the "DVD/CD-rom Drives" drop down -> Find your device -> 2X click it -> Got to the "Driver" tab -> Click Update Driver -> Follow instructions
    If this doesn't work go back to the drivers tab click the uninstall button than restart your computer at which point the "Found New Harware Wizard" will pop up and have you install the drive all over again which fixed it for me
My computer looking a support in this device------>>> what shoud i do?????
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Jun 09, 2011 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
My lite-on combo sohc-52364v wont read any dvd movies on my fresh instal os winxp, what should i do?
make sure all leads that are attached to your cdrw/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 31, 2011 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
I mite have deleted my lite-on combo sohc 5232k by mistake can you help to get it back plz
control panel administrive tools computer management device manager scroll to cd/dvd drives you should see either a red x or a yellow ! or a? right click to install drivers or
open up your computers side panel to access the lite combo drive unplug it then plug it in again from the electical lead
this should activate the found new hardware wizard then you might have to install the drivers for this device
hope this helps
Dec 09, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Trying 2 burn cd and my computer is sayind cant
try reinstalling the burner then restart ur computer if the problem still ocurs then right click on my computer then manage then device manager then right click on ur system name (eg tom234) then scan for hardware changes and update ur drive, if the problem still ocurs then change the cable(sata or pata) then try.
Nov 04, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Can the lite-on combo sohc-5236v burn DVD-Rs?
hi...ya sure u can burn the dvd's.
thank u..
rate me.
Feb 01, 2009 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
A Combo drive is a type of optical drive that combines CD-R/CD-RW recording capability with the ability to read (but not write) DVD media
Lite-on SOHC-5236V is a dvd/cd-rw combo drive so it can read and write CDs and read DVDs (but cannot burn DVDs)
to check the details of this product please click here
My lite-on combo burner lost driver
got to start->run and type "regedt32.exe", then press enter
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor
this should fix your problem
Feb 24, 2008 | Lite On (SOHC-5235K-BKRTL) CD-RW/DVD-ROM...
Lite-on sohc-5232k problem
Try system recovery if it is turned on, also you may try to unplug and plug back your drive from motherboard.
Good luck
Jan 31, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
LITEON DVD/CD-RW CAN READ DVD BUT NOT AUDIO/DATA CD.
I would suggest cleaning the drive with a cleaning dvd, $19.99 at most retailers. Or you can open up your computer and verify all connections to the drive are good, disconnect and re-connect to be sure. Hope this helps.
Sep 15, 2007 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Drive doesn't play CD-ROM but plays DVD games...
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Dec 26, 2006 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Lite On LITE-ON SOHC-5236V COMBO BK OEM (SOHC5236VBKOEM) Burner Logo
96 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
