Question about Canon LaserClass 9000L Plain Paper Fax
Cannot read LCD display
Somehow the lcd display is 90% gone. Cannot read anything. Tried to open to fix - but cannot open behind display and cannot take off plastic front cover.
Is there a way to restore LCD Display readout???
  • 186 Answers
No the display must be replaced. This is a common problem with that model!
Posted on Jan 03, 2008
Can't read any information in the window
hi,
Is your phone still works even w/o display?
there are several reasons why display disapprears.
1) probably your phone experience accidental impact and that causes lcd flex connector to get loose and causes no display.
2) defective or damaged flex connector.
3) defective lcd or open line connection to lcd.
You can fix it yourself if the problem is on no. 1 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using screws driver and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
for problem 2 and 3. You can order flex or lcd at ebay and change it yourself. be sure it is the right type for your unit. for dismantling your unit be sure to remember the parts, how they are installed and how to put it back. Be patient and this requires a lot of time to disassemble.
Good Luck!
Don't forget to rate me OK! Thanks...
Hope i helped you...
bst rgrds,
John
Jan 25, 2011 | Uniden Cordless Phone
My acer aspire fell. when i tried to open it. there is light on the power button but there is no picture on the screen. is there still a chance for my acer aspire notebook to be revived?
There is a chance of the LCD going bad.. If you have any external monitor try to swap the display on a external monitor.. If it woks well then the LCD has gone bad... If it doest work on that as well there might be more parts that have gone bad.. Contact the computer manufacture to get it fixed...
Sep 24, 2010 | Acer Aspire One PC Notebook
Turn on the monitor and the display will blink on for just a second then go black. power light is still on though.
if it's new then get it replaced...
else u need to get it fixed from a tech shop....one of the below is @ fault....
1 the LCD screen is gone,
2 the backlite (a small tubelite) is gone
3 the invertor board(a small PCB) behind is gone
May 10, 2010 | LG W2453V-PF 24" LCD HD Monitor
Display stopped showing anything
As it the result of a fall, it is the LCD bone or the display IC gone. LCD is replaceable but a gone IC means that the phone has to be scrapped because it is not economic to repair it.
Aug 16, 2009 | Nokia E61i Cellular Phone
Backlight on LCD display of Alpine TDA-5747E car radio gone
Here's the manual:
http://www.alpine.com.au/downloads/web_owners_manuals/cassette_owners_manuals/TDA-7548E_TDA-7547E.pdf
Jan 16, 2009 | Alpine TDA-7547
Screen So Bright I Can Barely See Anything...
Unfortunately the problem is the monitor has gone bad, more specifically and likely is the backlight which is used to light up the monitor. You could fix it by replacing the LCD, but you can get monitors cheaper than a replacement LCD so it wouldn't be very cost effective to do so.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
Dell Laditude monitor stopped working.
yes, it sounds like somehow the back light behind the LCD has gone out, cheaper to replace the whole LCD then to replace the light itself, but do connect a desktop monitor to it before you go out and buy one, if it works fine then you know its the lcd, if it does not work then it may be the internal video card.
Jan 02, 2008 | Computers & Internet
No LCD Display when opened at 90 degree
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
Jan 17, 2007 | Panasonic NV-GS35 Mini DV Digital...
Canon LaserClass 9000L Plain Paper Fax Logo
416 people viewed this question
old marine
old marine
