Question about Koss KS2503 System
Koss KS2503 will not come on
My Koss KS2503 will not work. One day it just would not turn on. I opened the system and found a blown fuse. I replaced this fuse only to watch it blow again and again with yet another new fuse. I have disconnected the "ribbons" from the circuit board and put them back on only to find the same thing occurred...no powering on. I called the company (1-800-USA-KOSS) and they said Koss electronics no longer has a phone number b/c they are going through some restructuring. Any help is MUCH appreciated!
Thanks!
  • Anonymous Jul 01, 2008
    same exact thing happened to me except I found a burned out capacitor on my power supply when I replaced the cap the fuse blew out again.
  • 3 Answers
You are better off buying a portable; u can get a magnovox DVD player for under $40 with DivX and connect it to the unit, and use it that way. www.kcwholeseller.com
Posted on Jan 07, 2008
Suddenly blows fuse as soon as plugged in why?
Usually a fuse blowing immediately means there is a short in the amp somewhere.
Jan 04, 2013 | Koss KS2503 System
Won't turn on
If the output module(s) has/have not failed (you need to know a bit to check this), then the power supply problem is probably traceable to a failed capacitor that caused the further failure of a switching transistor.
Locating this problem requires some electronic knowledge and at least a (digital) multimeter.
About the only thing you can do by eye is look for cans, normally mounted vertically on the board, mostly with the aluminum of the case visible at the top and shrink-wrapped sides that have values printed on them.
If you see any that have cracked tops or deposits on the board nearby, these may have caused the problem but the major component that is causing the fuse to blow is/are diodes or switching transistors on the AC side or shorted diodes on the DC side.
Because the failure might be related to bad capacitors, not having any way to check them pretty much precludes do-it-yourself repairs.
Replacing a blown fuse is sensible; replacing it twice is futile.
Jun 14, 2008 | Koss KS2503 System
Koss 2503 blows fuses
You could be having problems with just that outlet  It might not be able to handle that much electricity.  Try the system on a different outlet.  If it still doesn't work, try the system on an outlet on a different fuse.  On an overloaded fuse something as simple as curling iron can blow a fuse.  If none of these work then it's probably a power supply issue.  If the power supply isn't grounding right, this could be causing the system to overload and blow a fuse.  The only way to fix this would be to replace the power supply; however, this might not be practical or possible.  I would suggest simply buying a new system, but if you're up to it go ahead and try to get a new power supply.
Mar 02, 2008 | Koss KS2503 System
KOSS KS2503 CODE
Don't need to hack it,you could call Koss??
Aug 14, 2007 | Koss KS2503 System
No Power to the DVD player
Check your fuse. You probable blew it. Same thing happened to me months ago.
Aug 13, 2006 | Koss KS2503 System
Koss KS2503 System Logo
163 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Rick
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
