Question about Samsung DLP HL-P5663W 56" TV
Lines, colors, delayed images
HL-R4667W 46-in, has crossing lines in green, white and purple, sometimes delayed images over the correct image, However, the picture in picture is just fine. Any ideas? Bought it third party and the warranty company does not exist any more. Thanks, -Ted
  • vargas_ruben Feb 11, 2009
    same problem anyone knows why
Had the same problems.  This was after the a power outage.  Had green vertical and horizontal lines, like a checkered shirt.  But I searched online and found the simplest solution.  Just unplug the power.  And it worked.
Posted on Oct 08, 2008
    Novelist:
    Champion:
  • 211 Answers
Hi Ted,
It sounds like you need to do a convergence of the colors. Most newer sets have auto adjust features like an instant focus. Just click the switch and it will normally align the picture. If your set doesn't have this feature of auto adjust, click on the menu button and find the color adjustment screen and manually adjust all the cross hairs to the proper alignment ( the center of the screen is where the best alignment results is ). I hope this suggestion helped som.
If I can help more, call me at 307-266-4675 or email me at wyoed1@aol.com.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 05, 2008
  • Ed Meshechek
    Ed Meshechek Jan 24, 2008
    I'm sorry you found my answer to your question unusable. If you care to call me at 307-266-4675 or email me at wyoed1@aol.com I may be able to help you in a more extensive manner on your TV problem.
    If you want need more extensive convergence codes for your TV, the manufactures normally require you direct your problem to the manufacture as these codes are ( or seem to ) be kept in strict confindence from the consumer.
    Good Luck and I do hope you get yout problem straightened out.
    Ed
    NC Electronic
    Mills, Wyoming
Tip
Samsung HLP4663W Has Spots
If the TV has white spots or any color spots it will be the Light Engine
Part number is BP96-00564A Cost 950.00 some companys do offer a core refund for your old one sometimes 350.00 If your Colors are Green and Purple ,you will need to replace the Light Engine also!
on Dec 02, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
We have a model HL R4667W--Our picture just went
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Picture Problems
Here is how my picture looks like. It only happens on analog channel and digital channel is clear like picture-in-picture.
Jan 25, 2008 | Samsung HL-R4667W Rear Projection...
Distorted image, lines, convergence?
If the pip is fine then the digital board is bad. Have it replaced by an authorized Samsung service center as the hex settings have to be copied from the dmd to the new digital board
Jan 02, 2008 | Samsung HL-R4667W Rear Projection...
Problems in A85
This is a CCD sensor fault and you should find out from Canon if they will repair free of charge which they do on many models which have faulty sensor installed in the factory.
Sep 03, 2007 | Canon PowerShot A85 Digital Camera
Samsung DLP HL-P5663W 56" TV Logo
345 people viewed this question
Jerry Greenberg
Jerry Greenberg
