Question about Toshiba Satellite A135-S2276 Notebook
Display problem my wipro laptop screen ,right from the post screen displays a red color mixed dirty type of display
  • 238 Answers
Hi. its the lcd problem, the ink leak causes this issue..
Posted on Jan 05, 2008
Wipro is a sourcing company, not a manufacturer. You need to find out who manufactured it, contact their web site and download the drivers.
Wipro IT Services Consulting System Integration IT Outsourcing
Apr 08, 2016 | Computers & Internet
How do I fix a Sony TV that starts then screen goes blank
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 24, 2015 | Sony Televison & Video
Half the screen is white, half the screen is colorful
I would try using an external display. That will prove the GPU. If it is OK then the display is faulty, if not the GPU is faulty.
Nov 20, 2013 | ASUS Eee Computers & Internet
Code electronics element eldfw407
HDMI white balance settings should be re-calibrated. It is a skilled work. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Apr 30, 2013 | Element Electronics FLX-2610 26 in. LCD...
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
My wipro laptop keyboard keys are mixed up.if i press j 1 is displayed.its very difficult to type thrugh gon screen keyboard.plz help me.
You've got num lock on. To verify that, look for a Num Lock LED that is lit, should be near the screen on the keyboard side of the laptop. Often marked [1] or NumLock.
Simple fix, find the num lock key (or combination) and press it. If that doesn't work and the numlock LED is lit no matter what you press then you have a screwed up keyboard.
Your BIOS might be set to do this when the PC turns on. To fix that, look in BIOS setup for an option called "Boot Up NumLock" and turn it off.
Aug 13, 2010 | Computers & Internet
I've wipro notebook,it's SI No.09HBRR00100038-CPU and model no.WNBMBM4900.I'm not getting install audio driver,when start to install display an error 503 report and failure.What can i do?Please give me a...
* Error 503 is for Display Driver failure!
1. Try to install a updated version of display driver!
2. Restart your system,and configure display settings.
* Please explain ur "Audio driver problem", what type of error message u got ?
Jan 02, 2010 | Computers & Internet
Driver for Wipro Laptop
I have wipro laptop model no WIVNB7B1620. i have not driver for it. please help me.
Jun 22, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
