hello, on my hja8630 dishwasher,seems like it is stuck on the drian cycle. if u stop the cycle it still runs the only way 2 stop it draining is 2 turn the power off. please help
Comments:
Nov 05, 2009
- the switch was stickin on the flow away sencor,thanks for the help i changed the switch and fingers crossed it will keep workin
The problem is the water level switch. It is stuck in high level and does not detect that water has finished draining.
Most dishwashers have a floater switch located on one side at the bottom of the machine. In that case check if the floater is stuck. In your case the machine may not have a floater sensor, but like many Bosch it will rely on a pressure sensor located in the drain system. In that case the pressure sensor must be replaced.
Here the part list for your appliance. I am not sure how Bosh is calling the water level switch. I think the part is the overflow regulator (that is a pressure sensor). Better calling Part master at 0844 800 3456, to check if there are more water level sensing device on this model.
i have bosch excell dishwasher. it was working fine. we were away for 2 months.now came back-tried...
(More)
i have bosch excell dishwasher. it was working fine. we were away for 2 months.now came back-tried to use the dishwasher. it doesnt start any washing cycle. only gives a sound as if the water is draing every few seconds ,and on opening the dishwasher there is always some water on the floor of the dishwasher. can you kindly help
my frigidare dish washer is not located right next to the sink and it doesnt aiways pump all the...
(More)
my frigidare dish washer is not located right next to the sink and it doesnt aiways pump all the water out.is there a replacement pump with more power.
bosch exxcel slimline dishwasher starts cycle then stops after a few minutes still full of water...
(More)
bosch exxcel slimline dishwasher starts cycle then stops after a few minutes still full of water then keeps stopping and starting cycle can take up to 2 hours to complete . will start again if i empty water out of machine, checked hose and they're not blocked
