HOW TO FIX THE CONVERGENT PROBLEM ON A RCA 52" PROJECTION HDTV.
The convergence problem is likely to be in the convergence power supply which is located above and between the two boards which lie flat inside the chassis. The power supply has a chip on it which is a common problem (If it is not the transistor type then change the whole board.) part number on the chip where the metal heat sink is located. Part number may be STK 730-010 or STK 730-130 both number will work and must be unsoldered and new soldered in.
