Question about LG WM2688H Front Load Washer
Kenmore 41742042100 front load washer
Can't find the lint filter/screen. does not spin out all the water was told it was the lint screen my front load frigidaire did the same thing i would dump the filter and it would be fine till it needed it again
  • Anonymous Mar 16, 2014
    where is the lint filter on lg top loading washer
  • Anonymous Mar 17, 2014
    3.5 super capacity quiet tumble
    Sergeant:
    Champion:
  • 262 Answers
IT IN THE SAME PLACE AS THE FRIGIDAIRE YOU HAVE TO TAKE THE FRONT LOWER PANEL OFF
Posted on Jan 02, 2008
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Kenmore elite front load wont spin out code says fo2
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Dec 10, 2009 | Kenmore Elite 45986 Front Load Washer
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Kenmore 44042 Front Load Washer
Washer won't drain or spin.
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Check out your pump too, right after the filter for any block.
Apr 05, 2009 | Tecnik TKL9260 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Feb 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Kenmore front load washer
Machine is draining slow...probably from debris caught in dain hose or pump filter. Many people find safety pins, loose change and bra underwires lodged in the drain trapping lint, threads and other items which are narrowing or blocking the drain. The machine will only go into spin if it drains within a few (timed) seconds. Otherwise, the machine senses too high water level for spin out and shuts down.
Oct 07, 2008 | Kenmore 43142 Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Wet clothes, water in soap dispenser
Next check your drain, where the hose goes in behind, snake this out. And dont shove the hose in too deep, into the standpipe that is.
If this helps, rate me please.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 41742042100
the filter maybe blocked! or something caught in the pump or hose's going to it!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2688H Front Load Washer Logo
363 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
