Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
The ice dispeser chute cover on our ice dispenser no longer retracts out of the way to allow ice to fall down. A black plunger has fallen out of the chute. Can't see how to get front cover plate over the ice dispenser off? How do I get to the ice dispenser chute to see the ice dispenser mechanism to repair/replace it?
    Genius:
  • 1,073 Answers
Remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
Posted on Apr 11, 2008
The ice does not dispense from the chute. The chute freezes up and the ice can no longer travel down the chute and out the dispenser. Can this be fixed?
Yes the flap is supposed to close completly to stop the moist kitchen air freezing in the chute and blocking it
Sep 19, 2014 | Refrigerators
Ice Dispenser problem on KitchenAid KSCS25INSS00 Refrigerator
Hi DonaldG.
Are you sure it is something blocking the ice from falling?
You might want to check this, There is a troubleshoot section for ice problems, try to see if one of that solutions match your situation.
Jan 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kitchen Aid side by side model #kscs25inss00 The ice machine stopped working. I checked the solenoid valve for the ice machine and it works, as does the water dispeser in the door. The teeth in the ice...
First off is the water filter bad and or do you have one...if not and it is good...then you have pretty much diagnosed the problem correctly...as you said the old Ice maker gears turn and when they make a complete revolution they engage a trigger which signals the water solenoid to dispense water to the ice maker...another test is to fill the ice maker manually and see if it freezes (test the temp of the freezer...if it is not cold enough the ice maker will not work)...if ice is made (generally under 4 hours ) and it is not dumped...you need to replace the Ice maker...around $30 to $50depnding on brand and where you buy it...I shop Marcones Appliance parts the appliance repairman's friend...good quality cheap prices.
Good Luck I hope this helped...please rate me ...the Fang.
Mar 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice "door" on dispenser
cant bring up your model # but most of the time there is a plastic frame around the dispeser that pops or snaps in.. revealing the screws behind .. need something thin and do some gentel prying to see how it comes off
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
808 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
