Question about Lexmark P4350 All-In-One InkJet Printer
Resett ink levels
How can i reset the ink levels on the monitor
  • tomrca Aug 03, 2008
    are the cartridges resettable after a refill for the lexmark 4350
  • rel60411 Oct 23, 2008
    How do I reset the ink level on my lexmark all in one printer type 4350 after refilling the level on printer shows empty..
Are the cartridges resettable after a refill ?
Posted on Aug 03, 2008
I have had a Lexmark P4350 for some time and it has been OK. Now however it is in DUPLEX mode and I can't get back to normal. Help.
Posted on Nov 02, 2008
  • 233 Answers
What do you mean? you installed new cartridges but the ink level on the window shows the levels from the old cartridges?
Posted on Jan 04, 2008
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
When i try to print give message that '' ink has run out, replace the ink cartridge and close the cover" and so on the orange light is blinging.
Ink has run out mean in cartridge ink level counter reach zero level. Cartridge can not be used again even though it was refilled, because the counter still reads zero level.Replace the new cartridge or reset the counter using ip1600 ink level resetter. But I thinkthe more effective is to turn off the ink level counter. Just press the ink button about 30 seconds and then release. After that will appear ink level counters have been released.In the ink image on the monitor status will appear gray.
Feb 09, 2011 | Canon PIXMA iP1600 Printer
How do i go about refilling epson T5591/2/3/4/5/6
Before you can have unlimited refilling you must need this devices:
Option 1: The chip resetter which you will need to manually reset the cartridge before refilling to enable the printer to recognize a new cartridge.
Heres the link where you can buy the resetter:
http://cgi.ebay.ph/CHIP-RESETTER-For-EPSON-T5591-T077120-T078120-T0791-INK_W0QQitemZ290276640766QQcmdZViewItemQQptZBI_Toner?hash=item4395d607fe
Option 2: You a new set of empty cartridges with autoreset chips in it. No manual resetting needed, what you need is to refill and monitor the ink level.
Explanation: When the printer detected that the cartridge is empty, the printer sends data to the cartridges and the cartridge understand what the printer says, then the cartridge automatic chip resetter will re trigger the logic circuit built in into it to reset into full ink level.
Here is the link of the autoreset chip what Im taking about:
http://www.made-in-china.com/image/2f0j00wCVtjAmMPlchM/Refill-Cartridge-with-Auto-Reset-Chip-Canon-520-501-.jpg
Oct 21, 2009 | Office Equipment & Supplies
All the lights of Epson CX5500 is blinking
I think the resetter you have downloaded is for resetting waste ink counter, not for ink level. For resetting ink level counter (that reach zero) use hardware resetter or use use chip with autoreset function. Ink level reach zero is ink out, after resetting ink level reach 100% (full). But it's just program, not actually.
Sep 20, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
Jun 18, 2009 | Canon MP610 Photo All-In-One Printer
Canon Pixma iP1800 Ink Monitor won't work
Have you enabling ink status monitor? Find the resetter at indoreset.blogspot.com. For clening the waste ink u must open the case first. wash the waste ink pad.
May 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Continuous ink supply system for epson r285. Printer will not recognise the cartridges as full. have used the reset button on the cartridge but still no luck. any ideas?
Resetting the Epson Ink Monitoring System -
Even though the CFS maintains a constant level of ink in the cartridges, the Epson monitoring system will signal that the cartridges are empty after a cartridge full of ink has been used. This ink level information is stored on the Intelligent cartridge chip. These cartridge chips have to be reset with out lifting the cartridges. This is done with Inksupply.com Auto Reset Chips. On older Epson printers, before the Intelligent cartridge, it is done mechanically by removing and re-inserting the Inksupply.com switch activators. CFS cartridges must be reset without lifting them.
Previous Reset Methods -
The resetting methods have evolved over the past couple of years. First the Swedish Reset method was used, then the Equalizer Program, then the F-16 Chip Resetter, and now the Auto Reset Chips.
Hope this helps you. Good luck!
Oct 23, 2008 | Office Equipment & Supplies
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Lexmark P4350 All-In-One InkJet Printer Logo
465 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
