Question about HP Photosmart C3135 All-In-One InkJet Printer
Have new PC with VISTA
I don't believe printer is compatible
I cannot get printer to scan so I can save to file on PC
  • 2 more comments
  • CHERRY1244 Jan 10, 2008
  • ylyonnais Jan 24, 2009
    con't scan to save on computer.nothing happens when I push thescan button
  • debih12992 Mar 09, 2009
    i have windows vista and was given an hp c3135 photosmart all-in-one printer. Is this compatable and where would i find the software to down load it?
  • agnesj15 Mar 11, 2009
    I also can't scan
  • 3,587 Answers
Maybe these notes will help you resolve these issues?
Posted on Apr 30, 2008
Is there any possibility of making this printer compatible with windows 7
With Windows 7, I found that installing the Vista software/drivers in the compatibility mode works well.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on).
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | Dell A940 All-In-One InkJet Printer
I just bought a new HP Officejet 6500 Wireless All-in-One Printer - E709n. When I try to scan, it tells me I have no scan options. What do I do?
If you're using Vista, I had the same problem. To scan, go to MS Paint and choose "file" and "from scanner or camera" then save the file it scans. That worked well for me, as a go-around for Vista. Hope this helps! Lisa
Nov 10, 2010 | HP Officejet 6500 Wireless All-in-One...
Lexxmark x8350 PDF file is to big
I would start by looking at the actual data size of the file.
Next step, I would determine is the flow control between the printer and the PC is working correctly.
If the file is very large or intensive (lots of graphic images), I would break the file into several segments.
For example, pages one to five I would highlight and then do a "Save As" and name the new file as filename1.pdf.
Once the file is saved that way, I would move to page six and do a "Save As" filename6.PDF and so on until I have broken the file into more useful segments.
If you have the file and can send it to me at, I'll be happy to see if I can structure the file for you.
Dec 11, 2009 | Lexmark All-in-One Printer with PictBridge
Want to install umax astra 3400, using windows vista, won't recognize, what do I need to do?
There's only one way I've found to run this scanner on a computer with Vista, but its cheating since you really don't use Vista. Look at Knoppix 6.2 ( It has a scanner app (Xsane) that will run the Astra 3400 (using Plustek USB driver). The catch is you have to boot from the Knoppix CD (or DVD) which lets you run LINUX in your RAM, but won't mess with Vista on the hard drive. Save your scanned work to USB flash memory when done, then boot back to Vista and do whatever with those saved files. You have the option of various file types and even multipage PDFs.
Nov 16, 2009 | Umax Astra 3400 Flatbed Scanner
Need to get hp 1310 onto new pc, with vista
You can download the driver here: HP Full Feature Software and Drivers
To install the driver do the following:
  1. Click the Download only button.
    Note: Make sure the HP All-in-One device is "Not" connected to the computer before running the download file.
  2. Click the Run button to begin the download.
    Note: File is compressed and may take time to expand and run.
  3. Follow the on-screen instructions to begin the installation process.
  4. Click Finish.
  5. Connect the USB cable between the HP All-in-One device and the computer, then turn on the HP All-in-One device.
  6. Your product should be ready to print.
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
Does not save what i can.
maybe the files you have scan will be save in another folder search the files maybe the folder name that the files save was the date you scan. And also if you scan change the location of the files yuou want to save.(Browse)
Jan 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
Canon 3000f scanner only produces black pages
your vista OS is not compatible to ur pc. try to install XP service pack 2 or pack 3
Nov 28, 2008 | Canon CanoScan 4400f MultiFunction Color...
4200 hp scanjet not compatible with vista
I used the HP latest driver download named sj655en.exe from their website and after 29months of not working, it DID and DOES work now!
The HP Precision Scan LT interface has a little problem of "save as" naming your file since it does not show the file name but you can just add the file name to the folder name and then it'll save your scan.
All of my apps work fine using the import function to the HP Precision Scan LT application.
Since I know HP did NOT update their driver, I'm guessing it's Microsoft having changed something with Vista Home Premium.
Good luck with your re-try of getting the old HP4200C Scanjet working again on your Vista operting system.
Aug 13, 2008 | HP Scanjet 4200c Flatbed Scanner
HP Photosmart C3135 All-In-One InkJet Printer Logo
Ben Johnson
