Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough
to prevent refreezing. . The drain should be located below the evaporator coils
on the lower back of the freezer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Profile 26.6 cu. ft.
GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Water is not coming out of the water dispenser. The filter is fine and the ice machine is working....
(More)
Water is not coming out of the water dispenser. The filter is fine and the ice machine is working. There are no leaks; but I can't get any water from the fridge.
We just returned from a week's vacation and we can't get water out of our dispenser. I tried...
(More)
We just returned from a week's vacation and we can't get water out of our dispenser. I tried replacing the filter, but it didn't help. There is no lock feature. Could the line be frozen?
stuck at DE and flashing when unplug and replug work back 2 and half days then same thing happens...
(More)
stuck at DE and flashing when unplug and replug work back 2 and half days then same thing happens again
my ice crushes and cubes but gets stuck and will not come out, i have to open the door and push the...
(More)
my ice crushes and cubes but gets stuck and will not come out, i have to open the door and push the ice through
my freezer is icing up on the inside and the refrigerator and freezer are not as cold as they should...
(More)
my freezer is icing up on the inside and the refrigerator and freezer are not as cold as they should be. also, the water dispenser is really slow
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
