Question about JVC Everio GZ-MG130 Camcorder
Error code FF030C00
When I tried to copy direct to DVD, it authored the disc (took a long time) and then copied. I left and came back an hour later to find the disc ejected and a message saying the disc didn't burn with the error code FF030C00. I'm running Windows Vista Home Premium on an HP Pavillion. I hate Vista! Any solutions?
  • 7 more comments
  • Ginad4 Jan 07, 2008
    I get the same error. It was working fine for awhile but I deleted some old files and I am using diiferent dvds to burn on and now I cant burn anymore. I am using XP
  • deevine Feb 26, 2008
    Hi i have just had the mentioned error FF030C00 while using the programe DVDivine to burn a DVD. All went fine during the Authoring, when the process to burn started it hit 6% then stoped working my disk was ejected & the message Error FF030C00 was displayed. I noticed last night while i was away & when i came back my screen displayed DVDivine completed task successfuly, but no sign of my disk it was still inside.
    Oh how i hate Vista Prem programs, not only am i having trouble with Acer Arcade Live but also Nti CD & DVD Maker, it is always closing the program prematurely when i am trying to burn disks, or simply the programe dissapears off my screen in the middle of recording info & i keep having errors poping up & then the program says it is closing due to errors. I also have pop-ups saying to alter the burn speed to slow, that there is a dirty lens, my god this machine is only 4 weeks old & taken care of !
    Now the icing on the cake - it tells me i have Hardware Error.
    I have updated drivers & programes
    I am thinking it is just the model desktop i have because this is my second one since 02/01/08.
    When i use the drive for disks it is making a noise as if it is a coffee grinder which has become worse...
    Resolution.. I am waiting for an engineer to call & repair this one because it is a day over the 28 day exchange limit when i eventually spoke with customer service. Maybe he can give me some advice on this error & the others ?
    Am i doing something wrong - or am i just unlucky...
    DeeVine
  • Anna L Mar 01, 2008
    I'm having the Error Code: FF030C00 too, I was able to burn disks on the DVD+R the first three times using my Window XP burner. However, now I'm unable to burn from the JVC GZ-MG130U.. Help me please I have a 21st birthday party I have to burn.
  • Anonymous Jun 06, 2008
    still no solution ??? i am on XP... thank's !
  • Jennifer Gascon Jul 05, 2008
    I have the same problem with Error code FF030c00
    I unstalled then then restalled still did not work.... IPlease help I have a lot to burn and copy..
    There has to be solotion from those that created this problem?
  • Anonymous Aug 08, 2008
  • Anonymous Aug 14, 2008
    anche io ho lo stesso problema, durante la masterizzazione mi si presenta l'errore con codice FF030C00, dicendo che non riesce a terminare l'operazione di masterizzazione.
  • Anonymous Oct 14, 2008
    I HAVE THE SAME PROBLEM ON VISTA WITH ERROR CODE FF370303 TRY CLEANING DISC
I use the Everio exterio burner and only dvd- and JVC disks do not use the plus DVD
The computer did has problems and Vista did for me the burning in the Spanich
letters
Posted on Jan 09, 2008
Thank you for the suggestion. I tried 3 different DVD types DVD +R, -R & RW I found that I only get the error on the DVD +R
DVD Fab isn't copying DVDs anymore.
Try. reinstalling your media program.
Nov 20, 2016 | Televison & Video
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
JVC GZ 135 - ERROR CODE FF030C00
bij hert branden gaaf hij deze code.
hoe kan dat?
May 05, 2008 | JVC Everio GZ-MG130 Camcorder
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Power cinema NE
I am looking for a solution to my software problem when I bumped intoyour query and right after that a possible solution.
Here is the link... I hope it works
http://www2.cli.co.jp/products/ne/update_everioM7SD/pcm4e_update.htm
this one allows you to make 98 insted of just 50..goodluck
Oct 13, 2007 | JVC Everio GZ-MG21 Camcorder
Disc Read Error Sony DVD Handycam
I am just throwing these out there as food for thought. Make sure you ended the recording on that other side. If a DVD is left open(meaning more could be written to it) other dvd players have a hard time reading the info. Put in one of the 2 sided disc's that worked. how does the camera recognize the disc? Then insert the troubled disc and see if the disc info is being read the same. i.e. disk size, manufactuer, open/closed? Check for a firmware upgrade for your DVD burner/player(s). Let me know how things work out. Tim
Mar 05, 2007 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
JVC Everio GZ-MG130 Camcorder Logo
1,042 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
