Problem with Whirlpool GS460 Gas Kitchen Range
Whirlpool super Capacity 465 gas range-Door Lock
Hi- My oven door keeps locking by itself, then flashes "FSE1" on the display. The light inside also flashes on and off, all the while I have something in the oven baking. I have never set the self-cleaning function, and have no idea what is causing this!
Thanks for any advice!
Posted by avatar on Jan 02, 2008
    • By avatarGuest Sep 20, 2008
    • I self clean my oven and after it finish the whole thing shut off. door won't open and everything else is dead. i unplugged the oven and re plugged it after a few minutes. oven still dead
    • By avatarGuest Sep 15, 2008
    • after using the self cleaning option to clean the oven, the door remains locked. When pressing the slefcleaning botton again it give an error message of F-5.
    • By avatarGuest Sep 01, 2008
    • Had the same problem on electric version of this oven when trying to use the self-cleaning feature. After looking at the door and door locking mechanism to no avail, I tried applying slight (closing) pressure on the door after setting the oven to self-clean. After a few seconds, the "door locked" light illuminated and cleaning began.
    • By avatarhopearmour Feb 11, 2008
    • I'm having the same warning but have not tried to use the self cleaning feature.
    • By avatarmo122869 Jan 26, 2008
    • I did clean mine, but when it finished it flashed FSE1 and wouldn't unlock. I still can't get it to unlock.
    • By avatarChrysKyee Jan 10, 2008
    • I am having the same exact problem.
Solutions (3)
my oven door wont open since i self clean it
  • By Author imagekidd208 Nov 10, 2008
Just tried out the self cleaning and got this error.
Got this same error right before last thanksgiving and the door was locking and unlocking erratically and oven wouldn't heat. The only solution to get rid of the noise that we had at the time was to turn off the circuit breaker for the oven.
When we lifted up the top panel and cross referencing the wires with the online diagrams (Googled model number shown when opening drawer which got me to diagrams on http://www.partselect.com/) and my wife notice a hanging wire and said perhaps it shouldn't be hanging and it should plug into something. plugged it in as diagram shows and made a great turkey.
So I'll open this puppy up again and see what I can see and ask my wife to lend her keen eyeballs again ... if I don't post then we failed.
Good luck to the rest of you.
  • By Author imageespower Mar 29, 2008
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
  • By Author imageewis77 Feb 20, 2008
Suggested Solution (1)
Just unscrew the glass cover and change out the bulb.
  • by Author image medx217 Over a year ago
Source: How do you change the light bulb inside the oven
Was this solution helpful?
No
Yes
Add Your Solution
See all Whirlpool GS460 Gas Kitchen Range Problems
