Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
No water coming into dishwaser.
I have a Kitchenaid KUDI01TJ Dishwasher. It will run the entire cycle. But water does not come into the dishwsher. What could be the problem.
    Problem Solver:
  • 11 Answers
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Posted on May 14, 2008
I have a KitchenAid model KUDI01ILBT2. It was working fine until recently...The lights work fine, but when I push the start button it's delayed before it actually kicks on, and then it will...
sounds like you have a bad or clogged fill vavle,,you have water running to unit but not in unit,,,its still trying to dry dishes as if they wash...most dishwasher are hard wired to breaker and or not grounded,,,but only if you can shut of power pull dishwasher out remove water connection,,see if any **** is blocking vavle use flash lite if present...if so replace it..good luck you can not clean a dishwaser vavle..
Sep 03, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
The water does not go into the dishwaser
I would check the water inlet solenoid first to see if it's getting 110v. If it isn't it could be a bad timer/control switch. If it's getting 110v then the solenoid is probably bad and not opening to allow water through.
Dec 07, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Kitchenaid dishwasher
What are you draining into - an air gap to a disposal, air gap to drain, directly to disposal, or directly to drain? How long has this been happening, and have you done any plumbing work recently (new disposal?)
Greg
Jan 27, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Brand New GE Dishwasher quit on me
when a dishwasher first starts the pump kicks in for a few seconds before the timer starts the programme, then it should fill up etc, all you can do is confirm again the water supply is actually flowing to the machine, then call out the engineer under guarantee if this was or is not under guarantee, check the water solenoid valve for being open circuit (does it buzz when switched on) no, then faulty, yes then no water there / hope i have helped if so please rate me, thank you, please work safe
Sep 17, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Water inlet opening dishwasher kitchenaid
I would like to help you but I really dont know what type of problem you are having. If you couold give a more detailed description of your problem I may be of help to you.
Jul 10, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
232 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
