Question about UPS Battery Backup Systems
Western Digital My Book 500GB Essential Edition External Hardrive
Please Help!! I got one for Christmas, plugged it in, it put info on Computer, but no software or instrutions on what/how to back up my Photos,Etc.
Can anyone help with EASY info on what to do...I do not know much about Computers...Just want to be able to save Grandkids and family Photos...
Thanks for any help you can give me...
  • 95 Answers
Re: Western Digital My Book 500GB Essential Edition...
Did your WD 500 come with software? If so have you installed the software? Does windows see the new external hard drive under my computer? You can always drop and drag files and folders directly to your new hard drive. What operating system are you using? Please answer questions and then we will go from there.
Posted on Jan 10, 2008
0 characters
3 Points
How can you tell if the system is bad on apc back ups es 650
plug something (other then a computer)into it, turn the gadget on, then unplug the UPS. If the gadget continues active the UPS is OK. Generally after you have punched every button (circuit breakers). After that put a Volt/Ohm meter on the batteries (and the charging wires to check the charging curcuit is OK.
Apr 29, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Old refurbished compaq evo
Please right click on my computer icon select properties and then hardware next select the device manager tab and you will get a new window in that look for sound,video and let me know if you see any question mark besides it.
Sep 22, 2008 | UPS Battery Backup Systems
I want to connect an automotive external battery to my apc 500 es ups. plz help how to do it
You may be able to do this but it may NOT charge the external battery, you will have to see.... Anyway simply connect the battery up to the inside terminals Red- Red Black - Black.. with suitable wire & fittings make sure you have no shorts etc. ya good to go.
Feb 01, 2010 | APC Back-UPS® CS 500 UPS System
Winbond card
If the the sound card is a sound card not unboard sound yes before putting the sound card in other the computer write down all the info. on the card you are looking for the make and modal (you can get some of this info. from the device manager of the computer you are removing the card from) try to get the the driver from the comampy that made thr card, if not found, will have it. If you have any problems let me know.
Please rate me mysleuth
Mar 20, 2009 | UPS Battery Backup Systems
External hard disk and pcmcia cardbus
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Aug 04, 2008 | UPS Battery Backup Systems
Hi Jazzart
Frankly speaking i have never worked with wavelab essential but have used other editors.
But usually they have quite similar features such as this might be having audio/video clipping ,crossfading.merging and intesify,amplify and analysing tools.
first you select the clips you want to edit which are shown in the form of waveforms. Real time precision allows you to mark exact point from where you want to select a portion of the clip.
You can be more precise using the audio analyzer tool for clips .
Hope it helps .
Feb 13, 2008 | UPS Battery Backup Systems
No cd drive
check in control panel under system, device manager if it picks your device up if not it could be that its power cable is un plugged or its IDE cable is un plugged or it is conflicting with your hardrive, then you need to change the jumper behind the drive so that its not the same as your harddrive eg , hardrive slave and cd drive master etc.still not working then check if the drive is installed eg. check its driver.
Jan 16, 2008 | UPS Battery Backup Systems
High pitch frequency comming from the cpu
might be the fan on the processor or in your actual hardrive there are actual discs that spin ,this is most likely to be the problem, and sorry no solution 2 that except gettin a new hardrive.
Jan 15, 2008 | UPS Battery Backup Systems
How to use the Medion Digital Notepad
With my medion digital notebookproblems with the pen instead of writing left to right, it rights on the right to the bottom of the page on the right can you help please as well
Jan 02, 2008 | UPS Battery Backup Systems
UPS Battery Backup Systems Logo
48 people viewed this question
Top UPS Battery Backup Systems Experts
Jax Planet
Jax Planet
Sudeep Chatterjee
Sudeep Chatterjee
Are you an UPS Battery Backup System Expert? Answer questions, earn points and help others
