Question about RCA TH1101 MP3 Player
SD card and player recognized as seperate devices in Windows.
I know it is normal,but it sucks to have to make 2 separate playlists,
sync 2 times etc... Is there anyway to fix this??
  • 8,596 Answers
Re: SD card and player recognized as seperate devices in Windows. - RCA TH1101 MP3 Player MP3 & Digital Media Players
No there is not.
Posted on May 24, 2008
0 characters
3 Points
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
Itunes will not recognize my polaroid pmp350-4 music player. Can't save my music I bought on itunes.
For Windows folks, try iTunes Agent which you can get at CNET Download.
If you don't have the latest .NET framework for Windows, you'll get an error, so go to and get the latest version and install it.
Once you have iTunes agent up and running it will prompt you to configure it. If you've never used it before, just say no. You're indicating you don't have a previous profile you need to transfer. If all goes well, iTunes will launch and a pop-up will tell you iTunes Agent is ready to sync your devices.
To add a new device, make sure it's connected to your computer, then right click on the iTunes Agent icon in the system tray and choose preferences.
Press New. You'll get a warning letting you know that the first time you sync, all the data on the new device will be erased. So, be sure you have everything off the device before you go ahead.
Then fill out the fields, naming your device, and so on. Point the folder to the place on the new device where you want the music to go. You can choose particular playlists to associate with this device. Once you're done, press save.
To sync, right click on iTunes Agent and select synchronise devices.
Your selected songs will now be synced to the device
  • 1work-mp-playercell-phonepsp-portable-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href',''); }); "iTunes Agent Software"
    Download "Itunes Agent" from here:
  • 2work-mp-playercell-phonepsp-portable-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href',''); }); "Setting up iTunes Agent"
    Setting up "iTunes Agent" to recognize your player:
    It's real easy, after you've installed "iTunes Agent" it'll be on your "Desktop"....."Left Click" it.
    It'll now be in your "System Tray"... navigate to your "System Tray" and "Right Click" on the little "iTunes Agent" icon, click "Preferences..." , click the "New" button and set-up your configuration, fill in the fields that need to be set-up in order for your player to be recognized by "iTunes Agent".
    Follow the steps from the "iTunes Agent" pic I provided.
  • 3work-mp-playercell-phonepsp-portable-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href',''); }); "Setting up iTunes Agent"
    Your "Music Folder" field specifies where your music will be saved on your player, you could name this folder to anything you like example: "BigA2infinity's Jamz Folder" or if you like to have your player set up just like an iPod and save your files in separate folders i.e. 90' Music, Music Videos, My Top Rated, Recently Added, Recently Played, Top 25 Most Played.
    Or you could just leave the "Music Folder" field blank and have your music saved to the "ROOT" of your player example: "Removable F: drive" .
    In order for your player to be recognized, it must be recognized by a specific name.... in the "Recognize by folder/file" field type in a specific name, example: "BigA's Mp3 Player 2009" .
    So basically every folder name you've created in "iTunes Agent" set-up, make an extra folder with the same name in the "ROOT" of your player.
    Example #1: My music will be save in "BigA2infinity's Jamz Folder" on my player/mp3.
    Example #2: Just like an iPod, in order for an iPod to be recognized it needs a specific name in the "ROOT" of the iPod.... so create a folder in the "ROOT" of your player to recognize your none iPod/iPod-knock-Off/PSP/Mp3 Player, I created a folder named "BigA's Mp3 Player 2009" in the "ROOT" of my player/Mp3/PSP/iPod Knock-Off so it could be recognized.
    Follow the steps from the "iTunes Agent" pic I provided (same pic from Step 2).
  • 4work-mp-playercell-phonepsp-portable-1.4-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href',''); }); "Setting up iTunes Agent"
    "Fourth" and last step....
    The very last field in set-up is the "Associate with playlist" you could set this option to recognize any playlist you like, if you would like a playlist created with the name of your player set the option to "Use device name" .
  • Read more: How to Make iTunes Work On Any MP3 Player/Cell Phone/PSP Portable '
    Jan 04, 2011 | MP3 & Digital Media Players
    PLEASE Help with my sansa c200 mp3 player!
    The Sansa c200 has 2 versions, version 1 and 2.
    Check the version of the player:
    Go to Settings > System Info.
    Information for the firmware version and SD cards support:
    For 01.xx.xx firmware (c200 version 1) - up to 2GB microSD cards
    For 03.xx.xx firmware (c200 version 2) - up to 4GB microSDHC cards
    Note: Firmware is not interchangeable.
    Manual for c200 series:
    Manual for c200v2 series:
    For deleting files connect your player with the computer.
    When running Windows Media Player 11:
    1. Check the automatic SYNC routine for your player.
    How to get to the SET UP SYNC
    When viewing WMP11 in full mode select SYNC or LIBRARY in the top of WMP11, seeing the Sansa player listed on the left.
    Right click on the player and select SET UP SYNC... to go to the SYNC options.
    When "Sync this device automatically" is selected, all playlist in the computers' Library will be transferred to the player again, even the previous deleted files. Disable this function to prevent unwanted SYNC.
    2. Remove playlists from the library in set up sync, to get the playlists you would like to keep on the player.
    Need more help ? Just post a comment.
    Dec 10, 2009 | SanDisk Sansa c200 MP3 Player
    These directions only apply to the Philips SA6045/37:
    It's not going to be easy, because you will have to do two undesirable things: 1) Set your player up for auto-sync, which will result in the player adding unwanted media files to your player without your consent - and possibly overloading your player; and 2) You will have to roll back to Windows Media Player 10.
    If you ask me, it's not worth it, but here's the procedure:
    1. Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
    2. Hook up the Player to the computer, allow a few minutes for the Windows Media player to recognize and detect the connection of the Player.
    3. Click on the Sync tab.
    4. Click on “Sync settings” or “Set up sync”
    5. In the pop-up window, select the playlists that you want to sync
    6. Click “OK”, the sync will start automatically
    Note: playlists never show up in the device panel under the sync tab of Windows media Player even if they are on your device. Check on your device whether you can see the playlist.
    -Tha Mp3 Doctor
    Sep 12, 2008 | Philips GoGear Flash MP3 Player
    Sansa m250 playlists
    First you need to set your Sansa m250 mp3 player to MTP mode:
    ) Tap your menu button and select "Settings" > "USB".
    2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
    Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
    However, the music can still be accessed by switching the player back to MSC mode.
    To transfer a playlist using Windows Media Player version 10:
    - Make sure device is showing as an "audio device" and in MTP mode
    - Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
    - Select the Sync tab and click "Sync settings"
    - Check "Synchronize device automatically"
    - Set "View" to "All Playlists"
    - Place a check next to the playlists they want to transfer to device
    - Media Player should then sync those lists once you hit OK.
    Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
    Hope this helps
    Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
    Seperate Playlists
    Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
    May 31, 2008 | Philips SA1100 MP3 Player
    Playlists on the MicroSD card?
    You just reminded me. I took my SD card out and put it into my phone. I'll replace it in the Sansa and see what happens. So far, synching with WMP works, but still not Napster (where I do all my purchases). oh well.
    I'll try putting my card back in. Maybe a DMR key was on it. Also, I may have changed the name of my player. Lookign into a couple options. Back later/another day.
    Feb 12, 2008 | SanDisk Sansa e260 MP3 Player
    Using the extended memory feature via SD card
    With my Joybee 130, the SD card appears as a separate drive when you plug the player in. In Media Player, I have to select the correct storage device and set up the transfer by playlist using Tools Options Device, then Sync the device. If you are using Explorer to copy files to your device, again, check to see if a second drive letter appears in the directory tree. Good luck
    Dec 09, 2007 | MP3 & Digital Media Players
    Sync to internal and external memory without duplicates
    Hi try to go MY COMPUTER then go in the the drive check the folder it should have the micro sD folder from there you can just take the song and put them in the folder you want this is the other way i know how to put music in hope it helps.
    Feb 26, 2007 | SanDisk Sansa e140 MP3 Player
    Sync to player and memory card without duplicates
    I got this from: Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
    Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
    RCA TH1101 MP3 Player Logo
    Top RCA MP3 & Digital Media Players Experts
    Gyula Lacz
    Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
