Question about Sony DAV-C700 System
Poor picture quality
I have had the DAV-C700 system for about 6 or 7 years. I have for a while now noticed diagonal lines running through the picture when I played a DVD. These lines are diagonal, straight (not wavey) and pixilated. I tried running a cleaner disk in it but that made no inprovement. I have checked all the cables. I get the same lines was using the colorstream connection, as well as the single RCA video cable. I have not tried the S-video connection yet. The same lines appear when I feed a DVD signal from another player into an auxillary vidoe jack and sent it out through the Sony.
  • 1 more comment
  • buck_35_98 Nov 22, 2008
    I have this problem too. Have you found any solutions?
  • Ross Thompson Nov 29, 2008
    I have a similar problem with a DAV-C700 purchased in 1999. Diagonal/vertical lines alternating red and green across the display. I am using the component video outputs. If aged electrolytic cap's in PS are the culprits, which ones need to be replaced. Specificity would be appreciated.
  • freedlepp Feb 22, 2009
    I have the same problem as bikerider428 with the DAV-C700. It gets extremely hot after running a short while.
    Problem Solver:
  • 8 Answers
A lot of "aged" problems relate to the power supply with this type of unit. If you are a handy chap and know what capacitors are you will find that finding and replacing the "dry" caps in the power supply will fix most problems including streaky pix and crackly audio.
Posted on Mar 10, 2008
How to assemble carson telescope
Look at the picture on this web site:
http://www.opticsplanet.net/carson-50mm-aim-telescope.html
Notice that the "diagonal" goes into the telescope first and then the eyepiece goes into the diagonal.
This is a very poor quality telescope with plastic focuser and even the eyepieces are plastic. Read my TIPS on my profile page. 50mm is exactly the same aperture as a pair of 10x50mm binoculars. For Astronomy the binoculars would have been more useful than this small telescope.
Jul 10, 2010 | Carson Optical Carson 50mm Refractor...
Sony DAV-C700 DVD player not working
is there any display in the LCD screen of your player??
Jun 28, 2008 | Sony DAV-C700 System
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Sony DAV-C990 can't get it off the standby mode
Unplug DAV-C990 from AC outlet for couple of minutes, replug back in and power it up. If problem still exist then home theater has got problem in amplifier output section. Let me know the results to help you more.
Jun 12, 2009 | Sony DAV-C700 System
Video1, video 2 humm
Replace C602 on dvd board. noise on 10v line causing problem.
Jan 19, 2009 | Sony DAV-FC7 System
Diagonal lines through the picture of Samsung DLP set.
Poor solder connections, resolder convergence ICs or you may beed to replace them.
Dec 27, 2008 | Samsung HLN5065W 50" Rear Projection...
Lines on tv
Jan 27, 2008 | Sony DAV-C700 System
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
DAV-C700 overheated
Dec 01, 2007 | Sony DAV-C700 System
Sony DAV C700 DVD Player
Nov 13, 2007 | Sony DAV-C700 System
Sony DAV-C700 System Logo
106 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
