Question about EliteGroup L7VMM2 Motherboard
Power LED on but no boot up
Plugging in the power supply, the mobo LED light inside becomes lit. I hit the power button and the power LED light becomes lit but nothing else kicks in (fans, HDs, bios, etc.). There's a "Test Switch" on the power supply so I pressed it and held it in and the computer boots up normally as long as I keep my finger on the switch. If I were to let go, everything but the power LED light and the mobo LED light goes off. Say I hit the power button for 5 seconds to shut it off. Now when I hit the "Test Switch", the CPU fan and the power supply fan turn on but, of course, the HD and everything else won't because the power button wasn't hit. There are 5 wires coming from the power button area. Three wires are coming from to the dual-color power LED (green/red for standy mode). The other two come from the power button switch. The opposite end of the wires go to the motherboard grouped together. It seems that the power supply is operating fine when I hit the test switch on its side. This must mean that the mobo isn't signaling the power supply to power up when the power button is hit. I can't imagine the power button being bad because the LED does light up when the button is depressed. Does anyone have any ideas what could be wrong? The PS is working, the fans are working, when the FDD is NOT connected the CD tray opens. When the FDD is connected, the CD tray does not operate, the FDD light does NOT come on, the power LED does not light up and the computer will not POST
  • 2,427 Answers
It could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Posted on Jan 02, 2008
Am5630-u5202a acer aspire desktop windows vista, i press the button on the front it lights up the led inside and stays on but the computer itself wont. ie cpu fan ist turning or case fan or getting the...
Have you checked the keyboards light? Is it lit? When you press on the CAPSLOCK button, does the light changes in the keyboard?
Try to unplug the hard drive, and DVD from the mobo and see if it goes well.
If no go, try removing the RAM sticks and see what's on the screen when you turn it on. Then put each part back one by one, checking the computer for any change or something like that.
Dec 16, 2012 | Computers & Internet
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
ASUS P4XP-X won't energized after minimal repair
Either the board was damaged during the repair attempt, or was bad to begin with. The original problem description (black screen) sounds like typical mobo "no boot" trouble. The loose heatsink on the chip may have contributed to the failure, or it may have been simply coincidence. Given the low cost of motherboards, it's silly to spend any more time on attempting to diagnose and repair a problem. Just replace the board and move on.
May 10, 2009 | Computers & Internet
No boot up.
Power supply is easier to troubleshoot my local pc shop has used ones for $5 or if you have one laying around make sure you have one with the proper mobo connector 24pin will sometimes fit 20 pin as long as there are no transistors to close to plug just turn pc off unplug all drives and mobo plug in good supply and turn on if it works thats the problem if not probably mobo
Apr 10, 2009 | Shuttle SK43G (tsk43g) Barebone
E-Machines T2891 PC Desktop will not start when power button push
KingPin, is there any sign of life at all? Any lights, whiring, harddisk spinning?? Is there an LED (small light) visible on the motherboard when the power is on???
If nothing, certainly a power problem - but where. While you have the case open looking for the lit LED on the mobo, can you see any capacitors, the little cylinder-type components on the mobo circuit board that look like little batteries standing up, there'll be about half a dozen of them, that look like they may be bloated, or like a coke can left in the freezer about to explode. Do any of these capacitors look like they could be oozing goo, maybe a yellowish rusting liquid. If any do, this is not good.
If none of that applies the next step is to check your power supply. I would not suggest an amateur to do this over a step-by-step chat as it involves shorting out points and if the system is live, the wrong points shorted, well, guess you'd know what could happen (not good). The power supply is not easy to diagnos for errors, they're tricky buggers that can test well for voltage but once a load is put on them they roll over and play dead. Get an expert to test your power supply, very simple task of they plugging in a PSU tester (or borrow one, or buy one).
Please keep us informed on how you go - seriously, we grow stronger as we grow wiser when we finish a job.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 06, 2009 | EliteGroup P4M800PRO-M Motherboard
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
EliteGroup L7VMM2 Motherboard Logo
781 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
