Your water inlet valve on the back where the
water supply comes in is probably leaking. disconnect the water line coming out
of it and see if you have a slow drip. Try the dispenser to see if it's just
drips after use.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Profile PSW26P Stainless
GE Profile PSW26P Stainless Steel Side by Side Refrigerator
my ice maker auger sounds like it jams when I activate the lever. No ice comes out. I have taken the...
(More)
my ice maker auger sounds like it jams when I activate the lever. No ice comes out. I have taken the ice tray out and removed all the ice. It seems to work for a short time then it goes back to a jammed sound and nothing comes out. When we first got it we used the ice crusher feature a lot,did this affect the operation? Did we throw the auger out of line, or is there another problem? Is there a fix for this.
Ge profile freezer making humming sound. temp set for 0 degrees but going up as we talk now 38...
(More)
Ge profile freezer making humming sound. temp set for 0 degrees but going up as we talk now 38 degrees, refgrierator side is fine. please help
ge ps s26mgtd bb require service manual / water dispenser has slight leak / how can i access to make...
(More)
GE PS S26MGTD BB Require service manual / water dispenser has slight leak / how can I access to make repair / not sure how to remove plastic trim on front of left door. email infohere1@gmail.com Thanks in advance
We have a double door (bottom freezer drawer) GE Profile refrigerator. Water is draining into and...
(More)
We have a double door (bottom freezer drawer) GE Profile refrigerator. Water is draining into and pooling underneath the slide out deli drawer located at the bottom of the refrigerator just above the freezer drawer. This area can hold a lot of water. We have drained it out of there only twice in 2 years. Is water supposed to collect in this area?
I changed the water filter and about a week or so later the water stopped dispensing and no ice is...
(More)
I changed the water filter and about a week or so later the water stopped dispensing and no ice is being produced. When i push the lever in it does sound as if the selonoids are making. Any ideas?
