Question about Canon imageRUNNER 5000 Copier
COPIES RUNNING OFF THE TOP OF PAGE
I have had a couple of service calls regarding copies printing of the top of the page. It only happens with 11x17 paper and on the 2nd side of the sheet. The last time a technician was here he replace a tiny motor in the duplexer unit. It worked OK for about a week, but now the problem is back.
  • Canon Expert
  • 287 Answers
Hello kaymatt. I would truly like to help you and I have some questions and ideas that may do that. But as I am sure you know troubleshooting a problem remotely can be tough. I am game for the fight! :-) AND..... if nothing else this can help you help your tech diagnose the problem! I will proceed on the fact that you say that the problem only occurs on 11x17. Is it consistent? Is every image produced on 11x17, 2nd side, off the page (mis-registered)? Is the amount of misregistration consistent? That is to say off by the same amount. The reason I ask is that your copier is a digital device and therefore scans the image and converts it to a a stream of data that can be manipulated any number off ways prior to being produced on the paper. It can be enlarged,reduced,both simultaneously,shifted,reversed all because for a moment in time the image resides in memory waiting to be reproduced as per a number of instructions that the customer or the technician can alter. There is a software setting that the tech can access that sets the alignment of the image to paper. There are adjustments for left to right,up and down, magnification and more. All of these software adjustments can be made independently for 1st side and 2nd side. In fact have to be from time to time. I am sorry to be so long winded, but I bet you see where I am headed. I truly hopes this offers some help. If nothing else you just got some free amusing factoids! :-) Good luck and let me know if this helps.
Posted on Jan 06, 2008
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
Brother mfc j6710 tabloid print problems
ARE YOU PRINTING THICK PAPER IF YES THEN CHANGE THE PAPER TYPE THICK PAPER
Jun 22, 2017 | Brother "mfc-j6710dw professional series...
I have the SCX-4521. When I feed paper into the top to make copies, the copies come out with a black line in the middle of the page from top to bottom. However, if I make copies by laying the page on the...
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Sep 02, 2010 | Samsung Office Equipment & Supplies
My Xerox Workcentre is not printing out very dark even after changing out a new ink cartridge. The Drum is only about 8 months old. Also prints with line down the page occasionally. Different when...
If the copies are coming out with a school fence type image on the copy, it sounds like the low voltage power supply is causing the problem.
One other area to know about is, the laser head might have very dirty mirrors. The mirrors get a film of dirty haze on them causing the copies to print out very faint.
The repair is very involved and complicated.
In order to clean them, the laser assay would need to be removed and opend up. Very delicute care need to be taken when preforming this task.
Another area is if the copies are coming out light, suspect the software version is not up todate. A serivce call might have to be made on it. The service person can update the software on the machine.
Good luck and be safe.
Aug 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Canon MF5750--copies come out with black streak (smear) from top to bottom of pages when printing. Changed cartridge and cleaned window.
run twenty blank pages through the printer by printing just a period (.) on a document. Otherwise the sheet should be blank. This is a way of cleaning the toner or inkjet ink from the printer. By the time the twentyth page is printed, the page should be clean. If not, you may have to get the printer serviced. The canon service number is 1-800-423-2366 option 1.
Jan 28, 2010 | Office Equipment & Supplies
I'm trying to print 11x17 from Illustrator and every time it would only print half of the 11x17. WHY? any help please?
May be you forgot the Page Setup. If it is: open, copy all (ctrl+A then ctrl+C), File|New, set page to 11x17, paste and re-position.
May be Print Setup is incorrectly configured. Check it by activate the Show Page Tilling option on the menu.
Jun 30, 2009 | Konica Minolta magicolor 7450 Laser...
Top of page prints OK. Bottom blank
My first guess would be phone line problem. Print out an activity report (if you don't have a users manual you can download it at www.brother-usa.com ) and check to see if you have had any communication errors. If you notice no errors then make 50 test copies. If your test copies look good then I would lean towards a phone line problem. if they come out like you have described then I would start with your toner and drum first, second laser and third main board.
May 27, 2009 | Brother Office Equipment & Supplies
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon imageRUNNER 5000 Copier Logo
56 people viewed this question
old marine
old marine
