take bottom kick plate off,look underneath on left side and have someone else draw some water and see if line is cracked
Comments:
Nov 15, 2009
- don't know how you made out?if you have water under crisper draws you still have a blocked drain,you have to blow the drain out with a steamer or something,just melting it out will not cure that problem most of the time,usually something like a slime buildup or food particals will cause that
the crisper drawer supports on the front have broken off how do I get them out ? fridge model #...
(More)
the crisper drawer supports on the front have broken off how do I get them out ? fridge model # FRS6LR5EW5 I found the replacement part here http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=240423701&productGroupId=0046&supplierId=253&brandId=1428&documentId=R0608036&keySuffixId=NA&modelNumber=FRS6LR5EW5&keyId=0100&pageId=00003&productTypeId=0165000&searchModelNumber=FRS6LR5EW5&subCompDesc=Cabinet&brandDesc=FRIGIDAIRE&modelDesc=REFRIGERATOR&blt=11 but cannot remove the old ones. please help!
I have replaced my water filter several times to no avail. We have constant leakage from the filter...
(More)
I have replaced my water filter several times to no avail. We have constant leakage from the filter area. At first I thought the new filters were defective. (replaced 3) I have followed the Frigidaire manual when replacing the new filter...and gone through all the recommended steps...HELP !!
