Check power cord. Connect to another PC or laptop. If no LED lights....bad monitor...should have an amber or green. Check monitor connection pins for bent pins.
Need to be a little more specific with problem.
PLEASE VOTE IF THIS IS HELPFUL. GOOD LUCK AND THANKS.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 3100 PC Desktop
The clientpro 385 was recently restarted and now the power button flashes green every one to two...
(More)
The clientpro 385 was recently restarted and now the power button flashes green every one to two seconds. Unplugging the computer and plugging it back in changes nothing.
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the...
(More)
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the LED Toggle to light up, can this ground be connected to one of the computer 4 pin Molex Black wire. If so which one the Black Wire next to the Red Wire or the Yellow Wire.
computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store...
(More)
computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store but as soon as I plugged it in at home office it didn't turn off
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of...
(More)
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of processors are compatible with the motherboard of this computer. Please help mE THANKS!
When I bought an older model Dell PC I was assured it came with cd burner... Whenever I insert a...
(More)
When I bought an older model Dell PC I was assured it came with cd burner... Whenever I insert a blank cd to burn material on my pc says "to insert disc" as though its not reading it. I've tried a few brands of blank discs and no luck. Im hoping theres a way to solve this problem on my own....
