Go through all the source signals ie., cable, satelite, VCR, DVD, etc., to isolate if it is the TV or the source signal. If you get the same vertical line after going through all the sources, then see if there is a software upgrade that you can install. If not, then your TV screen is fu.k.d. up for sure.
Take the thing back to the store if your within your 30 day window. Call the manufacturer if your within your 1 year window.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Panasonic TH50PZ80BPED 50 in.
My television went out a year after i bought it, the tv would come on, but after about 6-10 seconds,...
(More)
My television went out a year after i bought it, the tv would come on, but after about 6-10 seconds, the display and sound would cut out. power cycle the tv and it would come back on for another 6-10 secs then go back out. The power to the TV does not go out, only the display and sound. I could change channels, and the TV would take the input, but now the display/sound is always dead, no matter how many times i power cycle the tv. What might cause this?
while installing npg cable to a new hdtv flat screen the coaxial cable arched with the back of the...
(More)
while installing npg cable to a new hdtv flat screen the coaxial cable arched with the back of the tv. causing the cable to melt. a standard def tv works just fine. the hdtv was working with the ps3 prior to cable being installed. the tv and the ps3 are now burned out as a result. any ideas???
I have a 65 inch Mitsubishi DLP and it is about 4.5 years old. There are several small gray circles...
(More)
I have a 65 inch Mitsubishi DLP and it is about 4.5 years old. There are several small gray circles near the top of the screen. From googling, it appears that the mirrors may need to be cleaned. Does anyone know what might be causing the gray circles?
I have a Panasonic 32" hdtv flat screen tube tv that I turned on and the light blinked then...
(More)
I have a Panasonic 32" hdtv flat screen tube tv that I turned on and the light blinked then went out and no tv. I think this may be the power supply. Would it be more economical to get this repaired or to just get a new tv?
Thank you, Kim
Samsung 50'' HP-T5054 screen went black has sound just no picture and smells of electronics burning....
(More)
Samsung 50'' HP-T5054 screen went black has sound just no picture and smells of electronics burning. Need help on where to start.
