Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
New LG Dishwasher Suddenly has no power
I checked breakers and tested another appliance on same plug. I checked wiring which looks fine.
  • 1 more comment
  • donscc Mar 11, 2008
    no power and replaced the control board
  • donscc May 11, 2010
    i replaced the control board and its still dead
  • Steve Papp Mar 10, 2013
    It is propubly the door swith, remove the door panel and check the switch. You can sort the swith, if you are familiar with electricity, if not please DO NOT TOUCH IT.
My LG dishwasher purchased in '06" began giving me IE errors,
so after talking with replacing the circuit board & the overflow switch it still didn't work.
I inspected the wire harness closer which os located behind the door and found the wires weere heated and frayed. Now I need to replace it but I feel that the problem will be resolved once I replace the main harness. There ar emany issues I read about nightmares with LG so I will not buy them again!!
Posted on Mar 14, 2008
  • 1,010 Answers
Did you check you door switch?
Posted on Mar 10, 2013
I replaced the control board and its still dead
    Problem Solver:
  • 15 Answers
Dead Control Board most likely.
Posted on Jan 05, 2008
Why was my dishwasher tripping the breaker when the ground wire touched the metal inside of the dishwasher?
The wiring may be reversed, colorwise, somewhere between the breaker panel and the dishwasher. Check for the correct polarity with a voltmeter.
Jul 19, 2014 | GE Dishwashers
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
No power lg dishwasher
A large dishwasher should have a dedicated circuit breaker in the circuit breaker panel, check to see if the breaker is on, tripped, or off, it should be on. If it is on, remove the panel cover and check for power coming out of the circuit breaker, if there is power coming out of the circuit breaker, check for power at the dish washer. Checking for power at the dishwasher may involve pulling the connector cord if any and check the power outlet for power, if there is no power outlet and the dishwasher is hard wired into an electric box, the electric box needs to be opened and the wires need to be tested for power, involving removing the wire splice nuts or wire nuts. Once the power is verified to the dishwasher and the washer is still with no power, a fuse should be sought inside the dishwasher control panel or that the power feed wires are properly spliced. A voltage testor is needed to test for power. electric shock hazard on live wires, please be carefull or call out a electrician or handyman if power testing skill is questionable.
Aug 11, 2012 | LG Dishwashers
When I push the power button on the dishwasher, there is now no power and the dishwasher does not turn on and there are no lights generated. The circuit breaker has been checked and that is not the...
Try a fan or light where the washer is plugged in. Suspect a bad power plug connection if the test works. The next suspect is a faulty microswitch connected with the door latch mechanism. You will likely need a test meter to track this down. Good luck!
Aug 15, 2010 | LG 24 in. LD-12BW5 Free-standing...
Dishwasher is not working. No power. I checked the electric box and everything is fine. Pulled dishwasher out, and it seems to be plugged in.
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Jul 31, 2009 | Dishwashers
NO POWER TO THE MACHINE
Hello. I can help you. Since you already checked out the power, skip that step and look at the latch.
Door switch
Wiring
Jun 05, 2009 | Viking 24 in. Professional Series VUD141...
The water doesn't stay at the bottom of Dishwasher & The detergent doesn'e get totaly emptied out from detergent Tray. It looks like the the residue remain in the Dishwasher & On Dishes too. Please, help...
hi there,
no indication that machine is not working,is there any power supply,check the power source,circuit breaker switch on.
Step 1: Check to make sure it's receiving power. If the unit plugs into a wall outlet, check the cord, the plug, and the outlet to make sure they're functioning properly. Also check the switch that controls the outlet to make sure it's turned on. Most built-in dishwashers are wired directly into a circuit. Check the main entrance panel for a blown fuse or tripped circuit breaker, and restore the circuit. If your home is an older one, the dishwasher may be wired to a separate entrance panel; look for a blown fuse or breaker at this panel, and restore the circuit.
Step 2: If the circuit is receiving power, and the wall outlet is controlled by a switch, the switch may be faulty. Test the switch with a voltage tester. Take off the switch cover plate and place one probe of the tester on one terminal and the other probe on the other terminal. If the tester bulb lights, the switch is functioning. If it doesn't light, the switch is faulty. Replace the switch with a new one of the same type.
this should be done by appliance technician,but if you have knowledge on this check it out.regads have a nice day,dont forget to rate me thank's
Apr 30, 2009 | GE 25 in. Profile PDW8200J Built-in...
The dishwasher doesnt turn on
1) Be sure the power is on, the door is latched, and the control is turned on. If absolutely nothing happens--in other words, nothing on the control panel is lit and there are no signs of life-- the appliance may not be receiving power. If the dishwasher's cord is plugged into a receptacle, check to see if it is a GFCI receptacle with a reset button. 20090521162623_gfci-receptacle.gifIf it is, push the reset. If it isn't or if the dishwasher's cord is wired directly to the electrical box, look for any other receptacles in the kitchen that have a reset and and try resetting them. (This is a longshot but it's easy to do and may solve the problem if the dishwasher is on the same circuit.) To test a receptacle for power, you can also just plug a hand-held appliance into it.
2) If that doesn't work, check the electrical panel for a tripped circuit breaker or blown fuse. If you find one, switch the breaker to "Off" and then back to "On" or replace the fuse.
3) If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. To solve a door switch problem, you may be able to adjust the door latch’s strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it). Regards Fixya..
Mar 24, 2009 | Whirlpool Gold GB2SHDXPS Stainless Steel
IS THERE AN INTERNAL BREAKER OR FUSE INSIDE A MAYTAG wc202
There is no fuse in this unit.
If unit has power but it is not cycling, then test wirings and circuit board.
Try first unplugging and plugging back the unit.
If there is no power at all , and the machine gives no sign of life, test the power cord and and the control assembly. In UK and other country there is also a fuse inside the power cord plug.
Here you find all diagrams and parts for your appliance <Click to open>.
Mar 15, 2009 | Dishwashers
Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | Dishwashers
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
561 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
