Problem with Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
how do I reset my sagem freeview
Posted by avatar on Oct 31, 2009
Solutions (1)
Best Solution
If I'm correct, then your box has frozen since a recent retune and is possibly (but not necessarily) displaying error codes 07 and 09. if this is the case then there is nothing you can do by way of a reset to remedy the fault.
If so, a number of Sagem models have shown incompatibilities with the recent Freeview retune, and your model (PVR 6280) is specifically listed as one ofthose affected (seehttp://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf ). Sagem are not the only ones, better known brands had problems as well.
The official advice is to contact Sagem directly on 0845 0900 316 to find out if they've scheduled an OAD (over air update).
If I'm wrong in my initial assumption and all you wish to perform is a straight system reset for any other reason then all you do is to switch the box on and then unplug it from the mains and from the aerial, leave it for five minutes to allow internal capacitors to discharge, and then refit the aerial plug and reconnect the mains power to it.
I hope that you've foundmy posting to be of use and ask only that you return the favour byrating my answer.
    • By avatarChris Sawyer Nov 19, 2010
    • Hi Guru,
      Many thanks for your advice. I rang Sagem,
Suggested Solution (2)
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
  • by Author image Zahc66 Over a year ago
    • By avatarcox_dean Dec 30, 2010
    • im sure the 09 error message on that model is a harddrive problem.may need a new one .they did have a web page with all the error numbers and solutions.
Source: i have a sagem dvr62160sl freeview box .i keep
Was this solution helpful?
No
Yes
Try Factory Reset, under the spanner menu
  • by Author image Chris Sawyer Over a year ago
Source: I have a Sagem DTR64160T freeview box which seems locked
No
Yes
Add Your Solution
See all Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Problems
