Please explain your machine problem further! "won't start" is just not enough information to offer a sensible solution. What does it do or not do? What have you tried to solve it? Had you just made some repair or modification when the problem began? Was it running and stopped suddenly and won't restart? The more information you can provide, the better chance that we can point you straight to a possible solution!
Need more info to help: -does it crank over? -is there fuel in the tank? -did you check your spark plug? -fuel gums up during prolonged (use Sta-bil fuel stabilizer to avoid this) storage. that would call for a major fuel system overhaul, including carb rebuild, fuel line replacement, fuel tank flush, etc.
You need to give information !! WHAT won't start??? What if anything does it do? When did this problem first occur? What led up to this problem? We need to know, at the very least, the model number of whatever it is that you have a problem with before we can offer a solution! The more descriptive information you give, the better the analysis and possible solution you will receive!
need JD 108 schematic I get a intermittent spark. I have replaced the magnito and spark plug. I am...
(More)
need JD 108 schematic I get a intermittent spark. I have replaced the magnito and spark plug. I am getting fuel and it turns over like crazy.
Ihave a simalar problem with a42 inch crafstman lawnntractor when i deprees the clutch will not go...
(More)
Ihave a simalar problem with a42 inch crafstman lawnntractor when i deprees the clutch will not go into gear.
