Question about Kenmore 24032\24036 Top Load Washer
Washer is filling and filling and filling...
Washer will stay on any setting I select.It will not progress through the cycle automatically.
If I turn it on it will continue to fill until it starts running out of the bottom, it I put it on spin it will spin until I open the lid?
Any suggestions?
  • Anonymous Jan 04, 2008
    I'm having the same problem after replaing the water supply/shut-off valve. I think I reset the wiring correctly. The only thing I can think of is possibly the wiring or water level shut off bulb?
Call 999
Posted on Jul 28, 2008
    Sergeant:
    Champion:
  • 262 Answers
CHECK YOU WATER LEVEL SWITCH IT SOUNDS LIKE IT IS STUCK ON THE FILL CYCLE
Posted on Jan 02, 2008
Why is the SP light flashing when the machine has filled with water and is ready to go
sp is the code for stand by or pause
so if you have set a soak period then it will stay there until the soak period has finished
if it is sp and you have pressed pause/start extra time the machine is in pause mode until you press start again
Sep 29, 2016 | Simpson Washing Machines
What part has gone bad on my ge front load washer?
I d look at the control board or timer
Dec 12, 2014 | GE Washing Machines
Washer starts and then shuts off without washing clothes
If it starts and fills then tumbles, and time has moved off the display then a couple of things if water remains in tub something has lodged in pump/or it has stripped, and or if no water and not spin cloths soaking wet then the door switch....
Apr 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Won't progress beyond wash cycle -- start light is flashing. Cannot switch from "normal" to delicate or any other choice. Maytag Neptune TL FAV6800AW
So I understand the issue. Does the wash cycle start up? By that I mean if you release the washer top from the base do the tumblers turn once the water fill cycle is complete?
If you don't have the FAV6800A/FAV9800A Service Manual (you can't get it on line anymore) see this post Clutch Fix I describe how to release the washer top from the base to observe the wash basket. Don't raise during the water fill cycle wait till that completes.
Does the key pad beep as you press the other cycle select key pads?
This could be a Control Board issue...........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Cold water will not shut off at end of spin cycle
electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Maytag washer will fill but never starts cycle
    motor is faulty most probably
    or mayby faulty capacitor on motor
    Mar 14, 2008 | Frigidaire ATF6000ES Front Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    70 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
