These shortcuts keys can be used when typing text in Blackberry:
If you want to type the alternate character on a key, hold the Alt key and press the character key.
For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
To insert a period (.), press the Space key twice. The next letter is capitalized.
To capitalize a letter, hold the letter key until the capitalized letter appears.
To turn NUM lock on, hold the Shift key and press the Alt key.
To turn NUM lock off, press the Alt key.
To insert an at sign (@) or a period (.) in an email address field, press the Space key.
To type a number in a number field, press a number key. You do not need to press the Alt key.
In order to type a number in a password field, hold the Alt key and press the number key.
To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Ok u probably have it set on T9Ab which u will see at the bottom left screen whenever ur sending a text, and thats how it works. It figures out what ur typing so u can just hit each letter that the words start w/ instead of clicking the number more than once just to get to a specific letter. Now to stop it from doing this, you go to options, go down to the 3rd option which says "Alpha" which means alphabet, which is where u r able to spell things out step by step how u prefer. Hope this helps you out, and good luck w/ ur phone, Im not too fond of it b/c it freezes a lot once uv had it 4a while. Merry CHRISTmas!!! =)
