Question about Lexmark X5150 All-In-One InkJet Printer
Clear paper jam
My printer says clear paper jam but there is no paper jamed in it
    Master:
  • 788 Answers
Sometimes there is little bits of paper stuck inside a sensor causing the printer to detect a jam. Use an air duster can to and shoot some air at all the sensors. The sensors look like little plastic fingers that get pushed down when paper moves over them.
Posted on Jan 10, 2008
Paper jamming sign lit up but no jammed paper seen
hi there shuld be paper inside or may be when u removed jamed paper not proper way some pice of paper struck in the sensor thats why paper jamed lit up clear the whole paper path it will solve problem if not there is any path sensor not working good just clean the path sensors
thanks
May 14, 2010 | Toshiba e-Studio163 Copier
Paper jamed
THERE SHOULD BE A COVER AT THE BACK OF THE PRINTER THAT COMES OUT(WITHOUT REMOVING ANY SCREWS). TRY REMOVING THAT COVER AND CLEAR THE PAPER JAM.
Apr 09, 2010 | Brother MFC 420CN All-In-One InkJet...
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Paper Jam
maybe there is more than 1 piece of paper jamed
Jun 29, 2009 | HP LaserJet 4 plus Printer
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam in Printer Moel HP PSC 1610 All-In-One. Printer Scanner Copier
paper jamed on the printer. cleared it and we still cannot print. It comes up "out of paper" -- removed the paper and insterted again and it still comes up the same. How can I clear that.
Dec 09, 2008 | Office Equipment & Supplies
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
Apr 20, 2008 | Office Equipment & Supplies
Lexmark X5150 All-In-One InkJet Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
