Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else) Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player. You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those with the correct drivers
look on website from compaq / hp for updated drivers and download them all driver for laptop and desktop are there also look in configuratie screen if driver are correct are installed and look also if audio out put are not disabled in the bios and also in software
My left clicker on my trackpad has been loose for a couple weeks, now it is extremely hard to click....
(More)
My left clicker on my trackpad has been loose for a couple weeks, now it is extremely hard to click. The little key can pop out and in easy and i noticed it might have something broken on it. i need to find a replacement. Where can i find it?
Have been using my MP G3010 scanner for 2 yrs. Suddenly, won't work and get...
(More)
Have been using my MP G3010 scanner for 2 yrs. Suddenly, won't work and get "DocumentViewer.msi file is missing" Can you help?
ho dovuto riparare il sistema operativo con l'inserimento del CD - tutto funziona in maniera...
(More)
ho dovuto riparare il sistema operativo con l'inserimento del CD - tutto funziona in maniera ottimale ma nella guida in linea resta vuota la sede dove dovrebbe apparire l'indice di ricerca alfabetico
