First time use and no water comes out of filter head. There is steam and water out of the frother and the pump sounds like it's working. We have followed the instructions to clear air-bubbles, however the problem persists.
Comments:
Nov 10, 2009
- Hi, yes we did find a solution in the end. We opened the unit up and discovered that there was a connector hanging loose. We plugged it back onto what looked like the correct terminal (a wiring diagram we found online helped) and all is fine now. Fingers crossed it works for you. Make sure you look thoroughly, it was the third time of looking before we spotted the broken connection.
Fingers crossed for you!
Me to! Not happy. Have you found any solutions to this? I don't really want to send away my machine that just arrived but also don't want to mess around with something that should work
Comments:
Nov 10, 2009
- Thank you. I actually had the same thought myself and after close inspection I found a loose plug and hoped for the best when I put it into what I assumend must be the right socket! Was a little bit worried the whole machine would blow up but all working well now!
We are going descale our baby gaggia machine but cannot remove the shower disc screw... Too tight......
(More)
We are going descale our baby gaggia machine but cannot remove the shower disc screw... Too tight... What safe product do you recommend we use to lubricate the screw? Any other suggestions about descaling? This is our first time, as the water way too slowly and burning our espresso...
Thank you so very much for your time and advice,
Shoshana
Had low pressure so de-scaled machine. Now water only comes out of one of four holes in the head...
(More)
Had low pressure so de-scaled machine. Now water only comes out of one of four holes in the head when shower screen removed. Is this normal? but pressure seems ok when brewing coffee.
my apologies, it is not a "classic". It is an "espresso" $235 at WholeLatteLove...
(More)
my apologies, it is not a "classic". It is an "espresso" $235 at WholeLatteLove 5 years ago. It has been regularly descaled and I use filtered water. Pump works, on-light works. Boiler won't heat up.
