Computer Ac Adapter
My Ac adaptor is bad can you send me another one
    Sergeant:
  • 319 Answers
You can get a universal adapter for speakers at Radio Shack or Best Buy.
Posted on Jan 02, 2008
  • 2,427 Answers
Yeah all you need is a universal variable adapter that could match your old adapters power and amp's and then just use the switch to change the polarity
Wire my ac jack for my samsung np365e5c
The AC adaptor goes into the AC socket, NOT the computer connection. The Computer connection is DC and comes from the DC side of the Adaptor. If you mean the DC socket has broken, then you need someone to replace it inside the computer.
If the AC adaptor has failed, you can buy a replacement ( 19V 3.16A 60W AC Adapter).
See the Manual
http://downloadcenter.samsung.com/content/UM/201408/20140829115137641/Win7_Manual_eng.pdf
Feb 23, 2015 | Samsung Computers & Internet
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
Dell latitude d520 starts with battery but not with ac adaptor
It could be a bad adapter, a short that drags everything down when plugged in.. could be a short inside the computer doing the same thing.
Borrow an adapter to see if you get the same result, if a friend or shop will help you with that.
A digital VOM could tell you if the right voltage is being put out by the adapter. Read on it, if it's supposed to be DC voltage and you get AC, the adapter is bad.
Oct 02, 2017 | Dell Latitude D520 Notebook
Monitor wont come on.green lite on the switching adaptor is off.Is the adaptor bad or monitor bad? How do I get a new adaptor?Model # WDS048120
The lamp on the power supply adapter should be on the minute it is plugged onto the AC outlet without the DC plug connected to the monitor, if it is not on then the AC adapter is bad, you can check the DC voltage with a digital meter. Post back so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | X2Gen MG19MY 19" LCD Monitor
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Lacking AC adaptor
Hello
Just recently i had the same problem just with my guitar pedal. My adapter broke and i had to make another plan.
So i was left with 2 options, either stop playing guitar or buy a new adapter, which is expensive. I then found a multiadaper. With this you can choose between AC or DC, and you have different options to which voltage you need to use. Best of all, it is not expensive at all and you an basically use it for everything which needs an adapter. You can buy this at any electronic shop
Really hope that this can help you
Sep 14, 2009 | Panasonic SDR-H18 USB Hard Drive
Laptop AC Adaptor
look here the problem can be of two types,,first the problem can be of the adapter or the port in the computer where the adapter pluggs in the computer,,look for any friends or relatives using the same computer with the same good adapter,,plugg it into the computer,,if u dnt c the problem then prob with the adapter or else prob with motherboard
best of luck,,keep me posted,,giv agood rating
May 26, 2009 | Dell Inspiron 6000 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
AC Adaptor
you can buy an adapter by emailing mike@sdexdata.com make sure you send the model no of the current adapter, they are around 39.00
Jan 27, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
535 people viewed this question
 Grubhead
Grubhead
