GE Washer Model WJSE4150B1WW
Our washer will just stop in the beginning, middle, end or anywhere during any cycle it doesn't matter. It can happen no matter where any of the settings are. It happens randomly without any kind of warning. I have tried jiggling the power cord, there appears to be no problem there. The magnetic safety switch seems to be OK. Any ideas short of replacing the whole control assembly?
  • Who-Noze Apr 26, 2008
    I have the same problem as Hind Sight. Same model washer too. Has there been a solution found to this problem yet? Mama's getting testy and I would rather not have to buy a new machine.
  • peterwjunk Apr 23, 2009
    Same problem here
    mine is a GE
    Model WSSH300GWW front loader.
    random metallic clicking sound that stops the cycle. I'm thinking the noise is the door lock disengaging, but I have no idea why....
    help please, anyone?
  • 166 Answers
You may try a couple of things. 1. unplug the machine overnight and then try it. 2. unplug the machine, take the backsplash loose where the timer/control panel is located. check to make sure that you don't have any rodents, bugs or roaches in the timer/control panel causing you problems such as chewed up wires or dead bugs in the control panel. If this is the case clean out the control panel and or repair any wires.
3 Replace control panel.
Posted on Nov 15, 2009
I have a GE stackable GUD27GSSJWW - we are on the second one with the same issue. The washer will begin to fill (wash or rinse cycle) and then just stop and the lights start flashing.
It may not be the washer. Have you checked that the filter on the water inlet has not got partially blocked with rubbish from your water. This is a common reason for a fault like this. You will need to remove the washer, remove the water inlet hoses and then remove the inlet filters and clean them. I was given a very expensive washer a few years back that refused to work for the owner who bought a new one. After cleaning the filter, it continued to work for many years after that.
Dec 08, 2017 | GE Washing Machines
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
Sep 6, 2013 - Uploaded by
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from
Nov 05, 2015 | Kenmore Washing Machines
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
362 people viewed this question
Top Washing Machines Experts
