Question about Sony KP-57HW40 57" Rear Projection Television
Reset how do you reset the television.
    President:
  • 4,402 Answers
Unplug it from the wall for 24 hours
Posted on Jan 02, 2008
How do i know if hdmi ports are bad?
It won't receive any signal. That's all. Then understand; it is faulty. What else?
Aug 28, 2016 | Panasonic VIERA TC-P55GT50 55-Inch 1080p...
How to reset Seki tv when it goes off and will not come back on
Seiki hard reset tv factory settings Flat Panel Televisions ...
www.fixya.com > ... > Flat Panel Televisions
Seiki flat panel televisions hard reset tv factory settings related questions and answers. Ask your Seiki questions. Get free help from flat panel television experts.
How to reset a seiki hd tv that keep reading no signal? - The ...
www.askmefast.com > Family & Relationships > Singles & Dating > Signal
To reset your seiki hd tv you just need to press on the menu: 0000 The TV will ....Getting to factory settings seiki tv ..... "How to reset seiki tv that reads no signal?
FAQ's ' seiki
Dec 19, 2015 | Seiki Televison & Video
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    My 48 inch television keeps turning off by itself is there a reset? I have to keep unplugging it.
    There is no such external reset button to this TV. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    As far the set do not switch On; you can't enter its service mode. If the set switches ON for a while; say 2 seconds or so, and then switches Off by itself, the main board is faulty.
    Dec 14, 2014 | Olevia LT42HVi 42 in. LCD Television
    My 65inch Mitsubishi started humming through the volume now the picture gets snowy
    follow this steps and fix it. God bless you
    • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
    Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
    Jul 31, 2013 | Mitsubishi WS-65807 65" Rear Projection...
    My 65inch Mitsubishi tv started humming and buzzing with the volume now picture is getting snowy at time
    Screen on toshiba 50HP66 is black with no audio
    reset the TV.follow this steps and fix it. God bless you
    Jul 31, 2013 | Toshiba Televison & Video
    Picture quality problem, getting yellow spots
    reset the projection TV, and fix it. God bless you
    Jul 31, 2013 | Hitachi Televison & Video
    Dull green screen
    reset the TV and fix it. God bless you
    Jul 30, 2013 | Philips 51PP9910 51" Rear Projection HDTV
    Mitsubishi ws - 5074 does it have a reset button
    There is an A/V reset button on the front panel of the TV.
    There is a converence reset in the user menu.
    To do a full system reset ( new out of box ) - press home 1 2 3 on the remote control. This will bring up the reset menu. Hit enter on the remote and your TV will reset to factory specs.
    Mar 19, 2013 | Mitsubishi VS-60719 60" Rear Projection...
    Sony KP-57HW40 57" Rear Projection Television Logo
    57 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
