Question about Dryers
Runs but no heat
The dryer runs full cycle but there is no heat
Dryer runs but there is no heat. I've checked the heating element and fuse and they are both intact. I reset the breaker and checked the electrical connection, and I still have no heat. I did have a lot of lint built up in the lint screen, but it is clean now.
    Problem Solver:
  • 9 Answers
If you are sure the element is fine use a multi meter to be sure you have continuity from the element back to the timer there could be a thermal fuse. Be sure you have 120V and 240 volt at the plug. If there is a seperate heat setting switch check continuty there. If all is good there chances are it is the timer itself. Normally the dials inside will wear and they will no longer push contact on the micro switch to turn on the element. You can test this with continuity by going from the power into the timer and to the element, have someone spin the timer by hand. You may find it jump when the odd contact is made but it will likley not be consistant. Some timers can be pulled apart and a tiny glob of epoxy on the right contact point will extend the life of the timer by a few years.
Posted on Jan 03, 2008
Dryer is spinning but not heating. we cleaned vents, unplugged dryer and replugged in. now it still won't heat and an hourglass symbol has appeared on control panel
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 11, 2015 | Samsung DV419AE Dryer
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
Why is my dryer running, but not heating up or drying the clothes?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Jun 23, 2014 | Kenmore Dryers
Sears dryer, model# 110.87562601.
How to check if Thermal Fuse or Heating element is blown
if the fuse was bad it just wouldn't work at all,it's non resetable,it will be hard to tell what's wrong now that it's working again but if the heat did go out and come back on there's a coil that runs through the heater,this breaks and then no heat but it could make a connection again,i ve found this one time out of 10 years or you could have a loose wire but it will be hard to tell until the heat shuts down again.also when was the last time you cleaned out the dryer,it should be cleaned out and blow out the vent line at least once a year.if the heat cuts out again and you need a hand let me know,also check the wires where the cord connects to the block on the back of dryer,if wires are loose this can happen.
Dec 27, 2012 | Dryers
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer will not heat up
hello. If your dryer doesn't heat, check these: Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 18, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
