Canon PIXMA MX310 All-In-One Printer
Problem for Canon PIXMA MX310 All-In-One Printer
Without black and colour cartridge ink how can i
By naveen2000si on Oct 31, 2009
without black and colour cartridge ink how can i use only scanner
Solution #1
posted on Oct 31, 2009
Not Rated)
swoop611
Rank: Guru
Rating: 86%, 72 votes
Hi Naveen, You must have at least a black cartridge fitted for the printer to allow any use at all. If no cartridges are fitted, then the printer will not operate. You can fit an old cartridge and then switch on, the printer will tell you that the cartridge is empty but you should now be able to access the scan functions using the buttons on the printer or the options in the printer software. You may even need to update the printer drivers before use if there is an update available. If the printer is not showing in control panel, then re-install the printer from scratch. If a black cartridge is installed but you are still unable to access the printer/scanner functions, the printer may have a logic error, and you will need to return it to the manufacturer for service.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX310 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX310 All-In-One
Do you recommend Canon PIXMA MX310 All-In-One Printer?
Answer
Answer
i cant get the scanner to work i followed instructions in booklet
Answer
I am being contacted by clients stating that faxes are not going through. We are receiving some, but... (More)
Answer
my printer says U163 Col check ink but ink cartridges seem ok?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , FL
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
